Sony PlayStation® 3 (60 GB) Console Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where online can I buy a replacement blu ray drive for my 80 gig ps3 model CECHLO1
Anonymous
Level 2:
Scholar:
  • Expert 163 Answers
  • Posted on Jan 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
163
Questions
0
Helped
31480
Points
422
you can find blu ray drives on ebay.com, amazon.com, newegg.com, and many others.
i hope i have helped and please let me know if you have any questions and let me know how it goes
My ps3 will no longer play ps3 games
If you are able to play Playstation 2 games, but not PS3 games then that means the blu ray laser has went bad. The lasers are a 2 part laser, The PS2 games take a lot less power to read than the blu ray or PS3 games, that is why you can still play PS2 games but not PS3s.
The lasers are a little bit pricy for these units, $60-$80 depending on which model laser is in your unit.
I recommend that you have a professional install the new laser in your unit because of the sensitive nature of the internal electronics.
One thing you don't want to do is damage the original blu ray drive mother board, the blu ray drive has Firmware on it that has to match the motherboard of the Ps3 unit or it will not play anything at all.
If you want me to replace the laser for you I can do that, just contact me and we can talk about it
[email protected]
My ps3 wont turn on , it keeps flashing the red light .
First try these steps -clean the air vents with vacuum cleaner -place the system in well -ventilated conditions -turn on the system and let it run for some time
OR your problem may be
Your system is shuttting down due to a blu-ray drive failure(most likely a problem with the pcb on the bluray drive.)You need to replace the compatible pcb you have to match up the revisions also.
It is very hard to find , these pcb boards are rarely listed online.
Find a console repair shop around your area, and see if they may have the part you need, otherwise sell your unit for parts. With blu-ray lasers being expensive, you can still easily get 80-100 for the unit.
My 80 Gig PS3 will no longer recognize that there is a dvd or game inserted.
Hi, unfortunately this is a very common problem with the PS3 and usually means the blu ray laser has become faulty. You can either give Sony a call and if it is under 1 year old they will replace it free of charge or you may have to pay around £130 for it to be repaired. You could try using a lens cleaner disc and see if that helps. Lastly you can have a look on ebay for a replacement drive. They usually sell for around £50 and are very easy to replace. If you google PS3 blu ray replacement you will find youtube guides on how to do it. You must however make sure you know the model of your PS3. It is on a white label on the back of the console and it starts CECH---. Next if you do replace the drive you will need to keep the circuit board that is screwed onto your drive as this is paired to the motherboard. If you do not swap the circuit boards the drive will never work. Have a look on youtube, the guides are pretty easy to follow.
Hope this helps and thank you for using FixYa
My PS3 is 3 yrs old never had a problem till last week when my blu-ray discs started freezing and then noticed games freezing also. So now we do not use it. We get a invalid disc error with blu-rays and...
Well from what i hear it is just that the laser inside the ps3 that reads the disc could be damaged, dirty, or even not in the right spot. sometimes the read laser that reads the disc can move from on spot to another if you hit the ps3 or if it falls (ETC).
Is the 80 gigga bite ps3 wireless
  • Swanky design with quiet operation
  • All games in high-definition
  • PSP-like, easy-to-use interface
  • Plays Profile 2.0 high-definition Blu-ray movies in addition to upscaling standard DVDs
  • Built-in Wi-Fi
  • 80GB hard drive
  • HDMI output with 1080p support; no external power supply
  • Free online gaming service.
PS3 BluRay Drive Issue
dont change the drive change the laser dhe drives are coded to each ps3 if that dosent work just change the hard drive whit the one that works
3answers
Ps3 wont play blu-ray but will play dvd
Maybe your PS3 Blu-ray playback partition has been damaged. But you can convert the Blu-ray to regular video and transfer to PS3 for playback.
Leawo Blu-ray Ripper is an easy-to-use Blu-ray to PS3 converting tool to help you rip and convert Blu-ray file to PS3 videos in only a few simple clicks. The below step-by-step guide would tell you the details on how to rip and convert Blu-ray to PS3 videos with Leawo Blu-ray to PS3 Converter.
Guide on how to convert Blu-ray to PS3 videos:
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
After the conversion is completed, now we should transer Blu-ray movie now in PS3 fridlier video format to PS3 for playing Blu-ray on PS3. Follow the steps below to do so.
Here is a simple step-by-step guide for transferring to or watching video files on your PS3 using a USB flash drive or an external hard drive.
Step 1: Plug a USB flash drive or an external hard drive into your computer and copy over the converted video files that you want to watch on your PS3.
Step 2: After the copying process is done, pull out the USB flash drive or the external hard drive from your computer and then plug it into one of the USB ports on the PS3.
Step 3: Navigate to "Video" on the PS3 XMB menu and find your device, hit triangle to view all contents and select the file you want and either copy it to the PS3 hard drive or just play it directly from the connected device.
By following the guidance above, you can achieve your goal of more safely and conveniently playing Blu-ray on PS3 or watching Blu-ray on PS3 for protecting either PS3 Blu-ray drive or your precious Blu-ray discs from being scratched.
3answers
Must i get a xbox 360 or Ps3?
Both consoles have advantages.
The Xbox 360 has a vast array of titles and has the biggest fan base of the two. If you connect the console to the internet, you can download games and movies through Xbox Live. You can also connect your PC to your Xbox 360 and use the console as a multimedia center using Windows Media Center.
The PS3 has a blu ray drive as standard, so you can watch blu ray movies through your PS3. DVD's are also upscaled up to 720p to improve the look of your movies. The PS3's online service is free, and allows you to download game demo's and downloadable content for games.
The Xbox 360's disadvantages are the fact you need to pay for access to Xbox Live, roughly £40 per year, but it does guarentee a reliable online service. Also earlier and cheaper models of the Xbox do not support full HD via HDMI.
The PS3 is very expensive and lacks quality titles. The console is also on a 10 year plan, so even though the console will outlast its rivals, it is likely to become outdated.
If you want to watch blu ray films and play games occasionally, go for the PS3. If you want a console with a lot of titles and a reliable online service,  get the 360. Of the two I'd choose the 360, but in 2 years or so I might need to reconsider.
My PS3 won't play DVDs or Blu-ray.
You may need to format the entire system and then update if you really need to watch the DVD that badly
you can move gamesaves to a memorystick before hand so you dont lost anything apart from demos and pics
pls rate.
2answers
PS3 wont read discs
Me too dude, down right disturbing. We are all getting F-ed!!!!
have an 80 gig machine, downloaded the aptch, played 1 game of CoD and it froze. WTF!!!
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
