Question about Toshiba 42H81 42" Rear Projection Television
Projected colors separated
I have a 6 year old Toshiba 42H81 and the colors have separated. The picture appears correctly, but the green is shifted a couple inches to the right. Everything else works fine. The picture used to just shiver for a couple minutes each time the TV was turned on, but now it's completely separated. When I bought it, the salesman did mention that after a couple years I would have to recalibrate or realign something inside the TV. Does anybody know how to fix it, or where I can fix it and how much should it cost?
Thanks a lot!
  • 1 more comment
  • kdixon34 Feb 08, 2008
    I have the same problem only it just happened one day out of nowhere.
  • Yulishna Feb 15, 2008
    I have a Toshiba 42H81 and I have the same problem, I've found the parts I need, but I don't know where to put them in the tv. Can you help me?
    Thank-you,
    Yuliya
  • tryntrust Feb 29, 2008
    My Toshiba 42H81 also have convergency problem, the red color has separated with both vertical and horizonal curve. Using one-touch-focus won't work.
    After reading solutions here and self-check the STK area, I found one resistor blown (R7711, 1W 1.8 ohm), and one bad PICO fuse F853 (125V, 1.25A). Don't know if the STK392-110 is OK or not, someone suggests that if resistor is burned-out, it must be caused by a failed STK IC.
    I know many online company sales STK392-110, but I have hard time to find the resistor and pico fuse. Where do your guys get the parts from?
    Scholar:
  • 30 Answers
I am working on the exact same problem with the same symptoms. Make sure the tv is unplgged for at least 5 minutes before poking around. The power cord can be unplugged from the power board and removed to keep anyone from plugging it in while you are working on it.
The STK's are the large 18 pin integrated circuits (chips) mounted to the large heat sink on the convergence board. This is the board on the right when viewed from the back of the TV.
The resistors are beneath the heat sink on the left side of the board. There are also fusible resistors, like #7711, on that side. There are NO pico fuses in this area.
Fuse 853 is on the Power board. This is the board on the left when viewed from the back of the TV. You can remove both boards in the carrier by carefully unplugging all connectors, noting their locations and routing.
To remove the high voltage wires from the splitter, mark them for position then grasp the boot and turn counter-clockwise about 10 degrees to unlock them and then pull up while holding the High voltage splitter. The small high voltage wire can be removed from the flyback transformer by pulling hard while holding the flyback.
STK392-110 can be replaced with STK392-120, STK392-180, STK394-160.
I have found most of the parts at newark.com. Also check out this site for some very good info: http://www.hometheatershack.com/forums/diy-repair-maintenance/5600-crt-based-rptv-convergence-repairs.html
btw: I am not affiliated in any way.
Make sure that while you have the boards out you look for any bad solder connections. A lot of problems arise or return because of this.
I hope this helps, I have been doing a lot of searching to get this info and hope it helps you. Too many people want to trickle the info and pretend they are giving you gold. A few hobbyists or people that can't afford to pay $300+ for repairs are not going to hurt their business.
Be safe and share knowlege freely!
Posted on Mar 02, 2010
    Problem Solver:
  • 9 Answers
1 - The Unit needs 2 ( STK-392-110 or Higher Voltage STK-392-160)
2- Also check the Resistors or Pico Fuses around the STK.
DJ
with
AAPCO Electronics Austin Texas
Posted on Feb 02, 2008
Cannot correct convergence the green line is double
The tv convergence board is dead.Any colors lines R,G,B mis alignment,have colors shadows or 3D picure look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Nov 06, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba TV Model 42H81 will not focus
Ur convergence it dead.Buy the kit and replace the ICS an the resister.Focus don't go that far.
Aug 11, 2009 | Toshiba 42H81 42" Rear Projection...
Colors separating...convergence issue
If you have any electronic soldering skills you can replace the convergence amp IC's which are part # STK 392-110. Buy the expensive IC's which are made by Sanyo and they last longer.You can buy these from www.encompassparts.com for about $30 each.
Buy some desoldering wick from radio shack to assist in removing the old IC's.
Jul 29, 2009 | Toshiba 42H81 42" Rear Projection...
Green
take the tub off of the back and there will be a red, blue , and green turn dials that adjust th focus and adjust the color apptitude adjust it accordingly
Dec 11, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba Model # 42H81 Picture Problem
Can you describe the issue a little more? It may be a convergence issue which is quite common on big screens. But there are quite a few issues that can cause a bad picture.
If it's convergence, you'll be able to tell by going to a news channel and looking at the text. If the convergence is bad you'll see a ghosting like image of 2 or 3 letters for each one that should be there.
Nov 25, 2007 | Toshiba 42H81 42" Rear Projection...
Dark Picture on my 5 year old 42H81
Any horizontal or sqiiggly lines in the picture or just a loss of light level?
Nov 07, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42h81 picture shifted
Are you still working on your set? I can help......T.
Jul 31, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
298 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
