Question about HP OfficeJet t65 All-In-One InkJet Printer
Hp T65 program to receive faxes
I have a HP T65 printer. I cannot find the instruction book to connect the FAX. I can send Faxes however I cannot receive faxes. Can you help me? Ann Bolls
e-mail ann.bolls@cox.net
  • 28 Answers
Press setup and change the following settings
basic fax settings:
1. auto answer : ON
2. Rings to answer = 3 rings (recommended)
Advanced fax settings:
1. distinctive ring pattern = all rings
2. ECM = OFF
3. Fax speed = slow
Posted on Jun 24, 2009
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
I have hp laserjet 3050 guide me how to connent fax and how to send fax
Sending and receiving faxes by using a computer
This section contains basic instructions for sending faxes by using the software that came with the allin-one. All other software-related topics are covered in the software Help, which can be opened from the software-program Help menu.
NOTE The HP fax software and HP ToolboxFX are not supported for Windows 98 or Windows Me. The HP ToolboxFX software is not supported for Macintosh.
NOTE Receiving faxes by using a computer is not supported for Macintosh.
You can fax electronic documents from your computer if you meet the following requirements:
? The all-in-one is connected directly to your computer or connected to your computer over a TCP/
IP network.
? The all-in-one software is installed on your computer.
? You are using Microsoft Windows 2000 or XP or Mac OS X V10.3 or Mac OS X V10.4.
To send a fax from the software (Windows 2000 or XP)
The procedure to send a fax varies according to your specifications. The most typical steps follow.
1. Click Start, click Programs (or All Programs in Windows XP), and then click Hewlett-Packard.
2. Click HP LaserJet all-in-one, and then click Send fax. The fax software appears.
3. Enter the fax number of one or more recipients.
4. Load the document in the automatic document feeder (ADF) input tray.
5. Include a cover page. (This step is optional.)
6. Click Send Now.
NOTE You can also send a fax from HP ToolboxFX by navigating to the Fax Tasks section
and clicking the Fax Send button.
Jul 22, 2011 | HP LaserJet 3050 All-In-One Printer
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
HOW TO EMAIL SCANNED DOCUMENTS FROM HP J4580 DIRECTLY?
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
Rings to Answer setting is five rings.)
Receive a fax manually
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
tray.
3. If you are currently on the phone with the sender, instruct the sender to press
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet t65 All-In-One InkJet Printer Logo
145 people viewed this question
Ben Johnson
