Kenwood system with tuner, cd player, casette player,intregrated amplifier and stereo power amplifier
The problem i have is when the speakers are hooked up there is either no sound or very little sound. i went online to see if i could find a manual to help see if i have things hooked up wrong, but i can't find the system on the kenwood web sight. either this system is old or it is under a different name. the system says it is a KA-996. if there is a different name or you think you might know what the problem is please let me know. also to hook a subwoofer up that has a right and left input output on the back and there is only one spot on the back of the amplifier how do i hook the sub up. do i have to use speaker wires or just one output.
  • 168 Answers
This website sells the owners manual for $9.99 and the service manual for $14.99 your stereo:
Here is the website:
http://www.user-manuals.com/advanced_search_result.php?keywords=KA-996&x=11&y=15
Hope this helps.
Could be too many different reasons for no/low output. My 1st guess would be the output transistors, but that again is guessing without knowing more info about the receiver.
Hopefully, its is something simple like the way it's hooked up, or if you have the wrong channel selected.
Good luck.
Posted on Feb 03, 2008
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
Sep 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have an old kenwood shelf system, with the following components:kenwood stereo power amplifier B-A9 100v 125w, kenwood C-A9 digital pre-amplifier/tuner, kenwood stereo cassette deck x-A9 plus a cd...
Thanks for your concern. I was badly in need of a manual and luckily enough I got across a friend who had one in Uganda. So that solved my problem.
Jan 01, 2010 | Kenwood XD-A55 CD Shelf System
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
Stereo cassette receiver--hums
There could be an open filter capacitor in the power supply.
Jul 13, 2017 | Kenwood Audio Players & Recorders
I need cables for a 1991 Panasonic shelf audio system
Hi Will, I searched for flat cables ,seem to no longer be stocked. If you are interested in selling the whole system let me know. I have one working condition with cables, would like to have spare units(parts). I will check one more site on cables for you.
Contact Gregg at: GreggASef1@zoominternet.net
Feb 06, 2009 | Panasonic Audio Players & Recorders
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
188 people viewed this question
 Grubhead
Grubhead
