Question about GE Spectra JBP78 Electric Kitchen Range
Broiler quit The broiler element will not heat up. In addition, when you turn on the self cleaning option the timer works but oven won't heat up to clean.
  • jmccoy Feb 02, 2008
    I tested the element and believe it is good. On my digital meter it read .02 I also tested the oven burner and it tested the same. Now I am trying to figure out if the erc control you talk about is the same as the clock control on the parts list. Is there a way to test the erc before purchasing one
  • 5,911 Answers
Have you checked the broil element resistance? Unplug the range and remove the back cover. Remove the wires from the broiler element and place a meter across the element posts. See if the element reads close to a short (It should read very low resistance if good). If the element reads infinite (open), you will have to replace the broil element. If the readings are normal, you may have a bad Electronic Range Control (ERC) board. The board controls the bake and broil features of the oven through two separate circuits. Usually a relay on the board goes bad. Since the ERC is considered "non-serviceable", replacement components can be hard to find. For this reason, the entire assembly is usually replaced. The ERC runs around $100 for your range, while the broil element can run anywhere from $35 to $60. Now...as far as your self-cleaning function is concerned - most electric ranges use BOTH elements to super heat the oven cavity to about 700 - 800 degrees F. With one of the elements not working, there's a good possibility the self-cleaning function will not work either Double check the items I mentioned and let me know if this helps you.
Posted on Feb 02, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 03, 2008
    Yes, the ERC and clock control are one in the same. Different manufacturers call them by different names, but they operate pretty much as the clock and main control for electric ranges. There is a way to check the ERC if you have a wiring diagram. Most ranges come with a basic wiring diagram located inside the console, or on the back of the range. You will need to pull the range out so you can access behind it. Unplug the range temporarily so you can remove the back access cover to get to the terminals on the board. Plug the unit back in and set the broil function. You will need to locate the broil relay on your wiring diagram and take a voltage reading across it. 0VAC is good, 220VAC the relay is bad. If the reading is good, the only thing between the relay and the element is wiring (in most cases). It may be worth your while to double check all your terminal connections BEFORE plugging the unit back in just to make sure no oxidation or loose contacts are keeping the unit from working. I hope this information helps you. Since I don't have a wiring diagram, I'm purely going on previous experience. Some ranges have a separate control board for the oven. I have only seen this on high end models, though. Let me know if you need anything else.
    PS The resistance readings for the broiler are normal and indicate a GOOD heating element.
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if anything looks strange (ie. burnt spot, hole, srrange color, or maybe no external sign)
Aug 15, 2009 | General Electric Stove/Oven/Range Chrome...
Oven won't heat
The only reason I know the answer to your question is because I am having the same problem. Our appliance quit working after we used the cleaning option. Both the bake and broiler quit at the same time. Our local repair man said that the problem is caused from a malfunctioning thermostat, which is about a $300 fix.
May 18, 2009 | Whirlpool RBS245PD Electric Single Oven
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE Spectra JBP78 Electric Kitchen Range Logo
312 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
