Question about Ovens
Whirlpool RF367LXS Ceramic Glass Range not working
Oven was on self-clean ok . Impatient staff attempted to abort self clean . Of course , oven has F5 code . The oven door lock is locked but the oven door is opened . How can this be reset or corrected . Thank you for this .
  • Anonymous Mar 29, 2008
    one element won't work
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Posted on Jan 10, 2009
Replace outer glass on oven gr440lxmc
You have to take the inner glass off first to get to the fixings for the outer glass. its normally 4-6 screws holding the frame for inner glass in place good idea to keep the parts in order for refix.
Sep 18, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Broken glass after cleaning cycle......is the oven wstill safe to use??
I would recommend that you do NOT use the oven until you get the glass replaced, remember that very high temperatures are involved and the other glass could easily shatter with the heat.
Dec 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I pressed self clean on magic chef ceramic range oven and get a dr code.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 28, 2010 | Magic Chef Ovens
Whirlpool wall oven glass door cracked+self cleaning feature does not work
heatman101
Oct 12, 2010 | Whirlpool Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I don't know where to look for a Glass Cooktop Replacement
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Jan 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
231 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
