Question about Toshiba 50H82 50" Rear Projection Television
50h82 red convergence ic replacement
Need the numbers for the replacement ic`s and where to order them.
thanks
    Sergeant:
  • 308 Answers
The quick answer is part number 23135090 from tritronicsinc.com or any nearby supplier. However, if the problem is intermittent (or even if it's not), you should be sure to check the solder connections along each end of the black or brown jumper wires near the IC's as they have caused problems in the past. Also, if the symptom you have is with the Red Convergence grid bowed at the top of screen, check Q783 p/n 23205037 as well. Good Luck and have Fun!
Posted on Feb 02, 2008
Toshiba 50h82 convergence problem?
Need to replace STK392-110 convergence locate these two chips on the left side near the inputs attached to huge heat sinks.
Thanks for using Fixya
Sep 28, 2008 | Toshiba 50H82 50" Rear Projection...
Will a REBUILT PTS PART number pd0637 toshiba hyper, number on part MVPU14 2L20DD work as a hyperboard in a 2002 50h82
Most of these hyperboard are inter changeable.But must Check the 2 STK convergence ICS munbers on the ICS parts have the same printed #---?
Apr 01, 2010 | Toshiba 50H82 50" Rear Projection...
RED HORIZONTAL CONVERGENCE OUT.INSTALLED NEW STK 392 110.SAME PROBLEM
Please check does STK IC getting +22 and -22 volts supply to work properly, check pico fuses that might blew off / open, replace it and check.
Thanks.
Oct 29, 2009 | Toshiba 50H82 50" Rear Projection...
Hi I have a toshiba 50h82 tv that is 7 years old with a convergence problem with the red and green lines that is going to cost $400 to fix but now that I am thinking about it before the convergence problem...
You are describing 2 different problems. The convergence problem can be fixed by either resoldering the convergence ICs or replacing them. These ICs cost about $25 each and there are 2. I suspect that the $4oo is for replacing the convergence board. This should not be necessary as the board can be fixed. Also, the brightness problem can be dirty CRTs, dirty mirror or faulty coolant fluid on the CRTs. If the picture was good prior to the convergence problem, the set is probably worth the repair if you can get the board fixed. While the board is being repaired, the service shop should be able to tell whether or not the brightness can be adjusted.
Dan
Oct 12, 2009 | Toshiba 50H82 50" Rear Projection...
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 42wh46p convergence problem
Yes Replace Both STKs also CK all low ohm resistors.
Feb 15, 2009 | Toshiba 50H82 50" Rear Projection...
Convergence for toshiba 50h82
Either mode is fine...just save your session when done!
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 16, 2008 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Q783 is a 2SJ512 (FET) with part number 23205037. These are not the easiest to test. If you suspect that it is bad, just replace it. It costs $2.48. I only have a listing for one convergence IC (STK-392-110), but if there are 2, replace the one labeled RVBVGV or just swap the two to see if the convergence shifts from vertical to horizontal.
Keep us posted.
Dan
Apr 17, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
