I'm getting a black box on my projection screen tv that blinks and displays <0063c50c> [e7e7] It only does it on one channel
  • azshidog Feb 02, 2008
    Whacking is really wierd but I'll try it. I thought you were joking. I will definitely unplug it to reset. That seems most logical. Thanks
    Genius:
  • 3,422 Answers
HI,
First thing to do is the reset and the whacking test. I give this a 50/50 chance of clearing it up.
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If these two procedures do nothing then:
The manual always knows the best.Go through the manual carefully and u will find the solution to ur problem..
Goodluck and Kind Regards
Please Don't forget to rate me as fixya..
Posted on Feb 02, 2008
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don&#39;t get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
I am trying to set up my new digitview 110 box, i have tryed to do an auto scan but it can not find any thing and i am not sure if i have the correct cabbles for it, any help would be great and even...
Make sure you have an ant. connected to the ant. INPUT on the>> 110 box <<then take a cable from the OUTPUT of >>110 box<< and connect it to the >> INPUT<< on your TV.
If you connect box to TV with a cable wire then put TV on channel 3 or 4
If you connect BOX to TV with the
Yellow red and white wires then put TV on VIDEO rather than channel 3 or 4 !
Auto program Digital Converter Box to receive channels...must have an ANTENAE connected to converter box!!!
May 19, 2010 | Televison & Video
I dont know how to tune in channels on my remote
Press MENU,then press < or > to display SETUP menu, press V until TV/cable is highlighted. Press < or > to highlight TV or cable depending on which you use. Press V to select CH Program,press < or > to start channel programming,when completed appears,press CH + or - ...hope this helps..
Mar 24, 2010 | Toshiba 27A33 27" TV
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
I'm trying to set up my JVC LT-32DF7BK. I've already attached a BT vision box, but the TV won't tune in any channels as it says no signal. I've checked all the leads and aerial point with another TV and...
Try an antenna directly on the tv to see if you get any stations. This will assure you that the tuner is working. Then hook up the new box and tune tv to channel 3 and turn box on. You should get some kind of display. If no luck you could hook audio/video cables from the audio/video output on the box to the video 1 input on the rear of your set. Then switch tv input to video 1 and turn box and tv on. This too, should give you something on the screen. Make sure the antenna is hooked up to the "ant. in" on the box. This should help, Russmann.
Jun 20, 2008 | JVC Televison & Video
Sony 52" rear projection tc
5 blinks means problem in the AKB (video) and 4 blinks means problem with the verticle deflection. Try this to get the screen to display any recent faults then get back to me and let me know what it said. Press the following buttons on the remote.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
Jan 13, 2008 | Sony KP-41T65 41" Rear Projection...
Viewing HDTV on a Sony 53" KP-53HS30
This TV is a projector - not a plasma. I can't see how you would get "burn in" on this set. It should handle an HD picture fine.
Jan 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
