Question about HP Pavilion MX75 17" CRT Monitor
RAM i want to upgrade my desktop. its almost six years old and i dont know which RAM i need for my computer and how can i back my whole computer?
  • pcMEM Jun 22, 2008
    I have a HP Pavilion mx75 desktop computer with Intel Pentium 4 processor @2.0GHz CPU and only 512-DDR SDRAM. I'm trying to find out whether it is smarter to buy new or upgrade this one? I hear Windows Vista is a real Pain. Thx. pcinMEM
  • 43 Answers
1st......Operating System?????
2nd.....Run Device manager to ascertain RAM installed
3rd.....Download Sandra Lite to find M/B specs.(Free Download)
4th.....Check if RAM is SODIMM,SDRAM,DDR,etc
5th.....Open PC case to ensure RAM slots available.
6th.....Purchase correct RAM.e.g.128MB->256MB,256MB->512MB,512MB->1024MB
Check to see if RAM slots are paired or not
If paired....2X128MB=256MB
2X256MB=512MB
2X512MB=1024MB
Posted on Feb 02, 2008
6ya staff
SOURCE:
I've got a stupid question. If my memory or RAM is
If you replaced the faulty ram with the same name brand and/or same specs. you should not need to reinstall anything unless the old ram corrupted the OS file system, or the files in those programs.Now sometimes when you replace faulty parts with newer ones or i should say upgraded parts,(like faster ram or cpu),some of microsoft OS's will make you reinstall the whole OS and then your programs,because it will blue screen when trying to boot into the OS,But there are ways around that too.If you need a fix to repair install just let me know what os your using.
Aug 09, 2011 | Computers & Internet
How to update my RAM. I dont know how to update my
More ram isn't going to necessarily speed up your computer. Ram basically allows you to multitask. The more ram you have the more things you can do at once. It helps with programs that are memory intensive. On older computers it's not always cost effective to upgrade ram because old ram remains expensive while newer DDR2 and DDR3 modules tend to be less expensive, however not compatible with your computer.
If you did want to add more its relatively simple to do. The side panel of a computer is usually held in place by two screws that can be access from the back of it. Make sure the computer is off and unplugged before messing with its innards. Once the side panel is removed look for something that looks similar to this:
The long yellow and green connectors are what I'm talking about. They will most likely be blue and black in your computer. There's tabs on either end of the connector that need to pushed outward and then the module comes right out.
Take that into your local computer shop and tell them you need more. One thing that you should try and determine is home much ram your computer supports. Often times older computers can't support more than 1-2 gigs. Anything over what's supported is just gonna go to waste, but not before costing you extra.
One thing i would suggest is moving away from Norton. In my experience Norton is a little bit of a memory (ram) hog. There's other free alternatives out there such as Avast and AVG that do just was well. You can also download a program called ccleaner. What this program does is clean unnecessary files that are taking up space. It also cleans your registry of invalid or no longer used entries which can slow a computer. Finally, it allows you to disable unnecessary programs from starting up when the computer starts which is often what ties up ram causing the computer to run slow.
I hope this was helpful and let me know if you have any questions.
Ray
Mar 02, 2011 | E-Machines eMachines Desktop PC
My compaq dx2450 wont register ram and its only about 8 months old i bought direct from hp but they wont help i really need to upgrade my ram
try adding one ram stick upgrade at a time, while leaving one original in the system till it boots and recognises the increase. repeat until finished adding all the new ram. if these measures dont work, its possible you have purchased ram that is not matching to the upgradable standards of your board. its important when adding ram to insure you match the ram speed with your replacements upgrade.
Jan 18, 2011 | HP Compaq DX2450 PC Desktop
I want to upgrade the standard 512mb RAM to 2GB. once installed do I just restart the computer or do I need to do something to allow the computer to recognize the new RAM?
You should be fine to just turn the computer on straight away as soon as you have installed your new RAM. The computer will recognize the new upgrade straight away provided you have got memory that is compatible with the desktop computer.
When you upgrade the RAM take the old RAM out and make sure your new RAM runs at the same speed as your old RAM.
From what i can remember the maximum RAM speed that an HP pavilion supports is 400MHz although it could well be 333MHz.
The RAM that's installed in the desktop at this moment in time will have the speed on it so you check with that.
Regards.
Jan 25, 2010 | HP Pavilion a450n PC Desktop
I need to know what are my options if i want to upgrade my gateway 500gr. Mamory, video card, power supply? what else can i do?
If your computer is more than 4 years old and you want a faster computer with a high end graphics card for games, RAM and larger hard disk and Windows 7, then I would seriously consider buying a new computer. You don't need to purchase a new monitor (keep your existing one), this will reduce the costs.
An upgraded old computer would not be as good as a new one, when you consider the costs and time involved with replace hardware and installing Windows on a larger hard drive, device drivers and programs etc.
Dec 02, 2009 | Gateway 500GR PC Desktop
My emachine is slow loading and constantly buffin, not being able to watch movies on utube My final question is how do I know my computer needs to be upgrade other that the fact that the emachine is an...
Hello
Well, the buffering on you tube is purely proportional with the speed of the internet connection you have, it means that the video plays faster than that which your internet connection is able to load, thus it starts to buffer.
To solve this you need to upgrade your internet connecting, upgrading the performance of your computer itself will have no effect on the internet connection.
As for the upgrading of your desktop, if you are happy with the performance, you don't need to upgrade. Most common upgrade is ram modules, which makes loading programs and such faster.
I would say a good method of knowing it is time to upgrade is to have a look if the parts for your computer is still widely available, if so, and you are happy with the performance, don't upgrade. If the parts for your desktop is discontinued of not very widely available, i would say it is a good choice to upgrade. Hope this can help you.
Kind regards
Andrea
Nov 17, 2009 | Computers & Internet
I cant conected to paltalk
Unplug the power to your internet and restart you computer. While computer is restarting plug power back into internet. If this does not help message me back and we can try something else.
Problem is probably you have too many programs open and you Ram is being used up. If it is a computer that is 2 or 3 years old you might want to consider a RAM Upgrade.
Jun 19, 2009 | Microsoft Windows Vista Business DVD...
Patriot desktop pc ram upgrade
it  may be the SDRRAM or DDR1 ram,check for it.if the ic's are in bold(Big in size ) with 5 or six in a row then it may be a DDR1 ram,otherwise it will be SDRRAM. if u have doubt again took your ram in pc as a sample and buy same as it is.
Aug 15, 2008 | Computers & Internet
I have a hp pavilion computer, I am trying to hook up a camera system I need to know if the motem has a router. where or how do I find out if my computer has a router
first you need to know how old is your computer. for instance my hp pavilion is almost six years old and i had to buy a router and your computer probably dont have a router either you have to buy the router and then connect it with your computer. and you computer probably dont have a modem either if i spelled it correctly these accessories dont come with the computer, you have to buy them and then set them with your computer.
Feb 02, 2008 | Computers & Internet
Toshiba a60 wont work with the interactive smartboard
YOU DONT HAVE ENOUGH RAM POWER WITH THIS COMPUTER MAX OUT THE MEMORY WHEN YOU UPGRADE
TO ATLEAST A GIG OR 512MB AT THE LEAST
Jan 18, 2008 | Toshiba Satellite A60 Notebook
Open Questions:
AOL MAil HeLpliNe {1-855*536*5666}#[email protected] NuMbER NEW MEXICO call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Nov 12, 2019 | AOL Computers & Internet
AOL MAil CuStOMeR {1*!855*!536!*+5666}#[email protected]@# SuPPoRt PHoNe NuMbER VIRGINIA call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
See all HP Pavilion MX75 17" CRT Monitor Questions
HP Pavilion MX75 17" CRT Monitor Logo
127 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
