Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Drive letter assignments
I messed up, formatted without making the recovery disks for my compac sr1300nx loaded a fresh xp home after using killdisk on the drive, everything is good up to authorizing with windows except the hard disk is (:H) and the cdrom is (:G) and the sd card slot is listed as (:C). Board is an A7V8X-LA, an ASUS made for compact/hp but not supported by ASUS. any ideas how to fix this.
  • bubby-joe Feb 02, 2008
    Thanks that worked, any idea as to WHY the drive order was wrong on a fresh install.
  • bubby-joe Feb 03, 2008
    I think the bios loads usb first then hard drives then optical drives, it's a Compac board made by ASUS but not supported by ASUS and has had problems with drive order before, I did a bios update but the order remained the same until I changed the drive order like you stated, now seems OK except for some missing drivers.
  • 43 Answers
Goto Control Panel>Administrative Tools>Computer Management>Disk Management.
Right click each drive to assign new drive path.Save & reboot.
Check My computer for changes
Posted on Feb 02, 2008
  • Gregory Young
    Gregory Young Feb 02, 2008
    That has a lot to do with Windows XP.If you did a full format & not a quickie,it should have assigned correct drive letters.
  • Gregory Young
    Gregory Young Feb 03, 2008
    Glad to help.
I posted that my lexar 4gb twist only shows on my computer as a disk. I cannot format it or do anything with it. When I try to open it I get this: Please insert disk" .I want to use this as storage....
You cannot use it as drive A: because A: and B: are reserved for floppu and zip drives. You will need to assign it any drive letter above the last drive letter in your pc. When working normal, the drive is automatically assigned the next letter available after the last drive letter. You may want to try formatting it again so it will be fresh and ready for use with your pc. Be sure to format it fat32 file system, (not ntfs).
Dec 22, 2013 | Electronics - Others
Tip
Get rid of ur virus and trojens...
if u have been using ur machine for many years and have virus and trojen in it and it's working slow....
do this
take a full back up of ur data on to a DVD/Zip Drive/Pen drive/USB HD etc.
also go to ur My Computer and note using pencil/paper the C: drive size (the Total Size, Used space, and Free space)
Download killdisk from my website...link is below...
copy it on to a CD...also create a boot disk....ensure ur computer can boot from the boot disk...check boot seq in BIOS....if u cannot boot from CD.....
boot from the boot disk....once u get the A: or D: replace the boot CD with the CD that has the Killdisk utility...
Run the killdisk utility.....type "killdisk" in the D: or A: prompt...
when killdisk loads.....note very carefuly....which is ur C: drive (check from the paper that u noted earlier the details about the C drive)
use the killdisk utility(F10) and wipe the drive...all sectors will become 000000......once the progrma is finished....this will wipe ur disk clean and get back to factory settings....all ur virus/trojens and all corrupt data will be gone....it will say that the free version will do only ONE PASS....one pass is enough....u can always repeat the process again if u want more than 1 Pass....then u can format the HD and load Windows fresh and load all ur programs....the killdisk program takes aprox 1 hr to complete for a 20GB disk....so if u have 200 GB in C: it will take aprox 10hrs to finish.....so be cool and sleep...dont intrupt the process....it will finish...be quite and patience....
on Dec 23, 2009 | Computers & Internet
Iomega 80GB external HDD not read because of I/O errors. This occurred after the drive was checked for volume errors
Try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files. download it from
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html
Sep 07, 2011 | Iomega Portable 80GB 4200rpm 480Mbps USB...
Xp did not give drive a letter
Go into Disk Management...Look for your drive and either it has not been formatted and assigned or just not assigned you can right click on the disk and assign to a drive letter.
Feb 17, 2010 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
I want to reboot my compaq presario 2100 to its original setting like when u first buy it.
ok...
u need the PC to be in factory setting....i guess so
u will need either of this....
Killdisk or Wipedisk
i have not used Wipedisk but i guess it's same as Killdisk...
Killdisk is a DOS utility that will wipe ur disk(make all ur Hardisk sectors 0000000.....)
but before using it ensure u bakup ur data from your PC....Killdisk takes about 30 mins to do 10GB of space so u can mutiply....if u have 100GM it will take 3 hrs to complete....the trial version of killdisk does only 1 pass(that's more than enough to wipe the disk to the original state)
you can always do the process twice to double sure that all sectors are cleared of corrupt data.
then u can load the OS from the OS disk
to use killdisk u will need to copy the program in a CD and also make a boot disk CD to boot the PC and get the drive letter of you CD/DVD rom drive at DOS prompt.
i suggest u make a boot disk before you wipe you PC
once u have booted from the boot disk, load the cd with the killdisk program and wipe your PC Hardisk
Dec 09, 2009 | Office Equipment & Supplies
Windiws cannot access the disk
try using the program Killdisk. This will permanently erase everything that has ever been written to the HD. Whenever I run into this problem, I run this on the HD and Presto, setup now recognizes the drive.
http://www.killdisk.com/downloadfree.htm
However, if this is a SATA drive, sometimes certain drivers must be loaded first. These drivers can be found at the manufacturer website. Once downloaded, you will have to use a floppy disk to load them (or usb flash drive if it is set up as bootable device). To load the drivers once downloaded and stored on bootable device, you will have to run winxp setup and press F6 when prompted at the bottom of the screen to load third party raid or scsi drivers. When you press F6, nothing different will happen. Setup files will continue to copy and setup will again try to look for your hard drive. When it does not find it, you will be prompted to look for drivers on your bootable device (the floppy/usb drive you loaded the drivers on).
Just note, after using killdisk, data recovery will not be possile for the partition you erased by using killdisk. What this means: Everytime your format a HD using Fdisk or windows setup, nothing is technicaly erased until that particular spot on the HD is written over, that is how data recovery businesses restore lost or erased data. Once you run killdisk, it re-writes over all data making it completely invisible to partition recovery programs. If you are not worried about any data on the disk, then this should be no concern for you, just some info.
If this does not help, I will be happy to walk you through the manual HD setup in winxp setup procedure, it is quite easy once you find what you need.
Hope this helped!
Oct 07, 2009 | Asrock K8Upgrade-VM800 Motherboard
Toshiba 5005-S504 recovery problem
Unfortunately , you are going to have to call Toshiba.
from the sound of it your recovery disks are failing and they have already formatted your harddrve
May 09, 2009 | Toshiba Satellite 5005-S504 Notebook
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Apr 16, 2009 | ASUS P5LD2-VM Motherboard
Drive No Longer Appears as an Available/Accessible Drive
goto disk management - right click and choose assign/change drive letter
Mar 18, 2009 | Electronics - Others
Erased hard drive, now nothing will load
Check to make sure that your Inspiron is set to boot from the CD-ROM drive.
It sounds like your laptop is trying to boot from the (now erased) hard drive first, finds that it can't, then stops without ever checking the CD-ROM drive for boot media.
At startup, hit F2 to go into the BIOS settings. Look for the "Boot Order" section. Make sure that your CD drive is listed first, then your hard drive.
Save your changes, and reboot with the WinXP installation CD in your drive. Now your laptop should boot from the CD and begin installation.
Good Luck!
*If you find the solution helpful, please rate it!*
Jun 04, 2008 | Hitachi TravelStar DK23EB Series DK23EB-40...
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
