Question about Mustek DV5500 Digital Camera
Power problems my camera turns off by itself seconds after being turned on....what can i do?
I find that if the power on button is hit twice or held long it cycles from on to off. New user
Posted on Apr 30, 2008
    Master:
    Sergeant:
  • 460 Answers
Dear Customer,
I advice you to use a new sets of Duracell or Energiser batteries as diital cameras drink up lots of power.
Posted on Feb 02, 2008
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
Camera turns on and turns off by itself with the
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 28, 2009 | Kodak EasyShare V1073 Digital Camera
Camera turns itself off
or this problem try the following:
* Try removing the memory card and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 SAMSUNG
Hope this will help
Thanks
Byron
Sep 25, 2009 | Samsung NV3 Digital Camera
When I turn it on it turns off by itself
The problem that you describe is frequently due to corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Casio Cameras
My camera wont stay on after i turn it on
Hi. It can be a problem with flash capacitor. To check if it is the case you should be able to power your camera at least for 10 seconds. If you can not power your camera for this time from batteries, try to use external DC 7.4V 2A power supply. After powering your camera just follow this procedure. 1. Turn on the camera. 2. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 3. Turn off the camera. 4. Turn on the camera. If after these operations camera can be powered from batteries and you can make pictures than the problem is in the flash capacitor which should be replaced. Or you still can make pictures with your camera without using a flash.
Jun 10, 2008 | Canon PowerShot S1 IS Digital Camera
DMC-FZ20 won't stay on after power up
In the camera setup menu there is an option which says power saver......increase the time frame in power saver...it will solve the problem
May 30, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Lens Error M425-12 (7F80) on HP M425
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2008 | HP Photosmart M425 Digital Camera
Aiptek ISDV2.4
When you say "turns itself off" do you mean the camera actually shuts off or does it just stop recording. If it just stops recording, it's because 10 seconds of video is all that will fit on the internal memory. If this is the case you just need to get a memory card for the camera.
If it's actually shutting off the power, there may be a problem with the camera. You could try posting about this problem at http://forums.steves-digicams.com/forums/view_forum.php?id=92
There are people there with a good amount of experience with these cameras.
Dec 30, 2007 | Aiptek IS-DV2 Camcorder
Camera switches itself off seconds after turning it on
This is a service center job and I think the lens assy motor is jammed. Take to a near by camera repair center
Feb 04, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Mustek DV5500 Digital Camera Logo
81 people viewed this question
Top Mustek Cameras Experts
Are you a Mustek Camera Expert? Answer questions, earn points and help others
