Sansui Q15 tube preamplifier
Please advise me on the tubes used in this pre. I am trying to restore it. One of the tubes is missing.Was told that it was a 5GK4 tube.Most of the other tube have no clear marking on them.Thanks
6ya staff
SOURCE:
Anonymous
  • 31 Answers
SOURCE: Using a tube pre amp with my CA Azur 640A?
There are many answers to your questions but Ill have a go with the basics...
Audio connections should be matched.... its called Frequency impedance,.... to get a signal along wires or cables (or Fibre) the Impedance of the cables and wires must be matched to the device they are connected to transfer the signal along the cables without distortion...
Manufacturers provide many sockets on the input side of amplifiers and preamplifiers to allow the consumer to connect various devices of different impedance.
They label these inputs like CD, or Tuner, or PHONO etc etc,
That means if you have a CD player it must be plugged into the CD input socket then the impedance will be correct and the sound will transfer along the CD cables correctly, without distortion..same with the Phono input etc...
You will find on the sound output to the speakers terminals are also labelled 4-6ohm, or 8-10ohm, these are the impedance expected for the coil ratings of the speakers them selves and its important to get the correct speakers to the correct out put terminals...
In your case all you have to do is follow these simple rules and all will be well....you say you have a squeeze box well there probably isnt a port labelled squeeze box so you need to experiment and try out each input port for the squeeze box to see what input gives you the correct sound output...Watch the Phono inputs as these are very sensative to input sound levels and must be treated very carefully as they have a double stage of sound amplification and as such you need to have the volume right down when connecting up the Phono inputs then increase the volume carefully after the cable connections are completed.
If you follow these rules then all will be well,,,,there is no difference if the Pre amp or Power amp is valve or transistor or FET or has IC outputs to the speaker the same impedance rules apply..just treat it as a box with input and output terminals and all the impedance will be taken care of for you...if you read the lables...
You need to connect you signal source to the Preamp inputs the out put from the Preamp connects to the power amp input then the power amp output goes to the speakers. this is a basic configuration for sound systems, there are other variations but are outside this discussion.
Cheers From YUBEUT
Posted on Nov 16, 2007
kirtec auto
  • 1348 Answers
SOURCE: Wanted: O-Manual or Photo, all the Labeling is gone on mine!
take the bottom cover off.look where the connectors go.the ones that go to the input selector switch are inputs.
the pair by themselves will be the outputs.
Posted on May 14, 2009
Anonymous
SOURCE: Looking for Owners Manual or Photo with Labeling.
I followed the recommendation that 'kirtec' left me;
Take the bottom cover off. look where the connectors go. The ones that go to the input selector switch are inputs.
The pairs by themselves will be outputs.
I was concerned about doing this as this is my 1st preamp w/ Tubes and I didn't get any spares. I'm really looking looking for an owners manual so I can find out how it's supposed to be labeled on the back + how it rated + what tubes it uses so I can get some spares.
Please don't get me wrong, I really appreciate his help - I was hoping there might be someone that's better at surfing the Web than I am who might be able to find one; I believe the vintage in 1982-1989.
I looked at the sites that advertise on here for owners/instruction manuals & couldn't find one ~ I'm not looking for something for nothing but I'm lost when it comes to finding one right now.
Appreciate everyone's time & energy who helped - Thanks!
FYI, the PreAmp is a 'Counterpoint Electronic Systems SA 3.1 Dual Channel Tube Pre amplifier'
Sandwichjohn or John B. from Illinois
Posted on May 15, 2009
petraman7
Scott Frye
  • 1175 Answers
SOURCE: Looking for schematic for sansui au70 tube amp
Try
www.servicemanuals.net
or
join www.audiokarma.org (its free) and ask around
PLease rate my help if this helps
Posted on Jan 26, 2010
John Cunningham
  • 6771 Answers
SOURCE: Yesturday tube pre worked and
Chances are the tube in PreSonus TubePre Amplifier will need to be replaced.
Posted on Aug 01, 2011
D104 wiring
TUG 8, TUG 9, TUP 8 or TUP 9? What radio? If it's a pre-amplified or power mic, there is a screwdriver adjustment under the base and a 9 volt battery in the base. The battery could be dead or the mic is turned down. If it is not a preamplified D 104, it wont be loud unless you run it on a Tram or Browning Tube Radio that accepts a high impedance mic. I hope this helps. :-)
Feb 13, 2014 | Radio Communications
My pre installed applications in nokia c3 is missing. How can I gain it back?
Restore the phone to factory settings, before that please take a back up of all the data in phone.
Kindly revert back for any further clarification
Apr 12, 2012 | Nokia C3 Cell Phone
Repais tv
Sounds like a shorted picture tube. Or it could be a blue drive problem. Hard to say. Thanks for using fixya.
Mar 03, 2010 | Sansui 27" TV
Sansui SV 2938 picture disply too big for screen
first is that tv have a tube if it does take back off and you will see what looks like a large light bulb tube and theres a clamp or two maybe even three clamps holding it inside the main big tube loosen the clamps being carefull not to get shocked by touching the wrong thing and the tube will slide back and forth it will also turn so place a mirror or just try looking around it when you adjust the tube to the correct messurement and make sure its level then lightly retighten screws be very carefull not to crack tube by over tightng hope this helped
Sep 09, 2009 | Televison & Video
May 14, 2009 | Audio Players & Recorders
Red colour missing
- A bended color pin at the VGA connector. (If pin one is bend then there would be no red color)
- A defective VGA signal cable. If the internal wires were broken then there would be missing colors. You can check if the signal cable is good or bad by doing a continuity test using a multimeter.
- Dry joints in the CRT board such as in the CRT socket pins, video pre amp and driver IC and even at the connector pins. In fact this problem contributed about 80% of Monitor color problems. Applying fresh solder would usually solve the color problem.
- A defective IC either in the Video Pre-amp or Video Driver IC.
- Faulty components in the CRT board. It could be a shorted driver transistor or even electrolytic capacitors that the ESR reading had shot up!
- A bad CRT socket. Sometimes decayed glue could cause the internal pins rusted and thus affecting the colors. Replacing only the CRT socket would definitely solve the problem.
- A weak or a defective picture tube (CRT tube). Yes, I do came across one of the electron gun (most probably the cathode materials had used up) in the tube faulty caused a missing color in the screen. There’s no way to repair this type of problem-the only way is to replace the CRT tube.
- In the newer type of Monitor, color setting is save in the EEPROM IC . Thus, if the EEprom data is corrupted, you would also get a missing color! The only way to repair it is to reprogram the IC or use a soft jig to tune it back the color setting.
Article Source: http://EzineArticles.com/?expert=Jestine_Yong
Dec 05, 2007 | Compaq P110 21" CRT Monitor
Sony kp48s35 (rear projection tv)
You need to have the crt px tubes checked for heater to cathode shorts, a picture tube restorer is needed to refurbish one or all three tubes to restore balance to tubes. Sony has a px muting built into the circuitry to save the tubes from being destroyed. If one tube is conducting more than one of the other two the imbalance is detected and causes picture (px) muting... blinking on & off the picture. Most repair shops have this crt restorer on hand.
Jun 07, 2007 | Sony KP-48S35 48" Rear Projection...
249 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
