LG Rear Projection Television Model RT-56NZ23RB - Fault
Rear projection television switches off after a few seconds when turned on, no picture got sound
  • 4 more comments
  • hskg2000 Feb 29, 2008
    there was a bang sound from the tv, then I realized an IC is blown up. changed the IC but still no pic and have sound for a few seconds. do you think the fly back transf has problem?
  • qwertyman73 Mar 03, 2008
    my LG rear projection tv has gone with a bang! now it will click like it wants to turn on but will not. can you solve this one?
    hope its gonna be cheap!!
  • sanjguru Mar 25, 2008
    I have got LG RT-56NZ23RB for abt 5 years and suddenly now noticed left hand side of screen image has pink shadow. Meaning if theres a person on left hand side of the screen, there will be pink boarder around that person and the image not clear as well. I tried auto convergence but not no luck. Any solution.
  • Anonymous May 07, 2009
    FILTER CAP IS CHARGED, SET HAS STANDBYE THEN LED GOES DULL WHEN IT GOES TO COME ON THEN CAP CHARGED
  • Anonymous Mar 19, 2014
    LG Rear Projection Television Model RT-56NZ23RB -turns on for 10 second with a good sound than gooes into stand by mode???The horizontal and vertical outputs checked,they are ok..What can i do after?
  • Anonymous Mar 27, 2014
    Model RT 44 54NA28
Go to LG.com.au and file a fault report, they will direct you to what you will need and how to get it.
Posted on Jun 04, 2008
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
Posted on Jun 09, 2008
  • hayes_hayden
    hayes_hayden Dec 24, 2012
    Did you replace the chips yourself? Please reply to haydenbrody1995@gmail.com It would be a great help if you could reply
  • 8,617 Answers
Check your horizontal output and regulators also vertcal output.You have a deflection problem either Horizontal or vertical outputs or one of the regulators are faulty. Let me know if you require more assistance.
Posted on Feb 02, 2008
Lg rt 56nz23rbLG Rear Projection Television Model RT-56NZ23RB -switches on for 10 seconds with sound but no picture and than switches off by going into stand by position.The horizontal and vertical outputs...
Thus problem sounds like you have some failed capacitors on the power supply circuitry. I have had this problem on an older TV and it was solved by replacing the popped caps. Do not try this repair yourself, unless you are confident you can do so safely! Also make sure that you unplug everything before poking around inside!
Mar 19, 2014 | Televison & Video
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
LG Rear Projection 44" will not turn on
Make sure you reinstall the lamp door as there is a lamp door switch that must be closed or the unit will not fire the lamp, there should be a small hole or opening on lamp door housing. Some people install the lamp without reclosing the door just to see if the unit works , just to find out if it will not work, and when it does;nt think something is wrong, they do not put the lamp door back on first. Not to say this is the case but it does happen.
Jun 12, 2009 | Samsung HCN5527W 55" Rear Projection...
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
Lg rt 56nz23rb
Hi there.
Replace the stk convergence ics and also the 3.9 0hm fusible resistors.
Sep 20, 2008 | LG RU-52SZ51D 52" Rear Projection...
RE LG DLP REAR PROJECTION TV
With the set switched on and operating, hold down MENU button on the remote control and MENU button on TV chassis at the same time for about 10 seconds
Dec 04, 2007 | LG RU-60SZ30 60" Rear Projection...
Televison & Video Logo
1,479 people viewed this question
Top Televison & Video Experts
Electro Med Services...
