Question about Rainbow E series Canister Wet/Dry Vacuum
Rain bow E series power head
The wire is about 10 inches long and the end away from the trigger has a protective sleeve on it. The end under the trigger asembly is held in place by a long clip like thing it is about 4 to 5 inches long and that end is in place.
    President:
  • 1,673 Answers
Maybe these pictures will help, I think your wire broke off by the hose.
Rain bow E series power head - 081b1ac.jpgttp://i.fixya.net/uploads/images/081b1ac.jpg" alt="081b1ac.jpg" class="h_mi" />
Posted on Feb 05, 2008
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Chord plug broke
go to any hardware or home store even dollar shops --where ever u choose to go buy a replacement/repair plug .this is not a hard repair cut off plug end strip cover back 1 inch and strip back the wires separate the repair plug usually 2 or 3 little screws- slide wire up into sleeve and connect green wire to u shaped connection- white to silver color[sometimes the connections are not colored ] -black to goldish connection put plug togeather and ur done
Dec 18, 2011 | Electrolux Vacuums
I need to reassemble my rainbow e series electrified hose handle
Yes, it is a ground wire. When you put it back together, make sure that the two halves of the hose handle are holding the wire up against the metal. I just had one apart the other day for the first time and if I recall correctly, the wire goes near the center for reassembly. Hope this helps!
Mar 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
How to replace the elboe on the power nozzle
wouldnt recommenddoing it urself as it may have warranty. But if u have the head off and the elbow apart im not sure what parts u have. If u have both these taken apart. It is pretty much self explanitory. u need to take the prongs out of the one end. At the other end ot the wires there r two attachements. The end that is at an angle attaches to the reset button which is by the L shaped part. The opther wire attaches either directly to the small motor itself, or to another wire which has a plastic cover on it. The wires that you took the prongs off of the rest along side the little knobby piece and then you wrap them around the middle of the knobby piece. Slide the elbow sleeve over the knobby piece and then turn it so u can bring the ends of the wires out of the little hole in the middle of the elbow sleeve. When the is done attach the two little clips back on the the elbow the one on the inside and the one on the outside at the back of the elbow. reattach the prongs to the ends of the wires put them into the notches about the middle of the elbow sleeve. Reattach the little cover and ur done. If u have the whole assembly. Take p/n cover apart and reattach wires where they r already connected inside the head. Put the head back together. Feel free to give me a call 1-866-966-9350.
Jul 13, 2008 | Electrolux Guardian Bagged Canister Vacuum
Power head handle wiring
Not sure, I had a chance to look at one earlier, there was a wire that came off of the hose and went to that point above the trigger. Is that wire by the trigger intact or broken off? I may be able to look it again on Monday.
Feb 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
That wire goes just above where the trigger is, take the trigger out and there is a slot that the end goes into.
Feb 01, 2008 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow E series power switch doesn't work
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Jun 25, 2006 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
53 people viewed this question
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
