Question about JVC RX-5020VBK Receiver
Jvc rx-5020v dolby digital problem
I think my dolby digital is burned out. It doesn't play in digital mode. All it does is flash with DIGITAL when selected at receiver. And I know the movie is digital mapped.
Also...If your BluRay player only has a optical output for audio you will need to swap the inputs on the JVC rx-5020v. Press the "settings" button repeatedly until "digital in" appears on the display. Now use the "adjust" up and down buttons until DVD is selected as option 2. It will look like something like: 1CD2DVD Note: this may bugger any other previous setup you have.
Posted on Apr 24, 2010
  • 8,596 Answers
It's not enough for the movie to be that way - you actually have to connect a Digital Audio cable from the the dvd player to this receiver (and the dvd player has to have a Digital Audio OUT)
Posted on Aug 14, 2008
I spilled a liquid in my jvc rx-502ov receiver and a message reads dsp micom ng what do i do?
You fried the poor thing to put it mildly, Get a different one end cut down on your partying ,(GUY) Unless you have money to burn
Dec 05, 2012 | JVC Rx 5020v Stereo Receiver
Can i plug in my i-pod and listen to it?
All you need is either a dock, which will keep the I-Pod powered up, or a 3.5mm plug to two RCA phono leads, which will also be needed for the dock, this plugs into your headphone socket of your I-Pod and the two RCA's into an aux socket on the JVC. You can then listen to it in Dolby Pro-Logic. You won't be able to listen in Dolby Digital, unless the I-Pod has Dolby Digital output, which will require a different lead.
Of course the sound source (music) would have to be recorded with Dolby Surround, to get the full benefit, but many are, they just don't say in the imformation given.
Mar 09, 2010 | JVC RX-6008V Receiver
I just moved and can only use 3 speakers with my jvc 1028. what setting should I use when watching TV?
Unless the TV has an output for Dolby Digital, you can only listen in stereo or a pro-logic modes, or other none digital mode. If you only connect 3 of the 5 speakers, then the other two channels will simply not be heard, but it shouldn't damage the amp.
Feb 28, 2010 | JVC RX-1028V Receiver
I have a PS3 hooked up via HDMI to my Yamaha RX-V465.When I play a blueray disc the signal info shows PCM.Shouldn't it show Dolby Digital or True HD?
Your PS3 probably has a setting for what digital bitstream it produces. Check it out. Dolby Digital is probably what you want.
Dec 27, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Analog only
You need to connect your source to your receiver with a Digital coax cable or a Optical cable to get true surround sound. Analog will only give you simulated surrond sound.
Mar 28, 2009 | JVC RX-5030/32 Receiver
Analog only
what cables are you using ?
if you are using anything but optical or coaxial
you will only get stereo sound
Mar 28, 2009 | JVC RX-5032 Dolby/DTS 5x100 Watts Receiver...
Dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Feb 03, 2008 | JVC RX-7030V Receiver
No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Nov 19, 2007 | JVC RX-778V
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
JVC RX-5020VBK Receiver Logo
851 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
