Question about Garmin GPSMAP 76Cx GPS Receiver
Using a DGPS on a 76csx
I was wondering if you can connect dgps receivers like the Garmin GBR-21 to the 76cx series. I know in the past there has been an option for RTCM connections on previous 76 series units, but it seems to be gone for the interface options, yet the specifications i have found online for the unit includes RCTM input. Can anyone shed some light on this?
There is no possibility to use DGPS with 76csx... due to the fact that 76csx receivers use chipset the 'sirf star III' series and this chipsets don't allow use any RTCM data.
regards,
frankie, poland.
Posted on Mar 24, 2008
What is DGPS?
DGPS stands for Differential Global Positioning System. DGPS achieves enhanced accuracy since the reference and user receivers both experience common errors that can be removed by the user. Position errors less than 10 meters are typically realized.
Feb 06, 2013 | Home Security
GPSmap 76CSx is not acquiring satellite
Update the unit using Garmins WebUpdater program, this may fix your issue as there was a chipset update that is crucial to acquiring satellites. here is a link to the software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 07, 2011 | Garmin GPSMAP 76CSx GPS Receiver
Frequently switches from dgps to gps fix .Why is this?
DGPS only works in areas where there is a DGPS beacon, and they're simply not that commonplace. Unlike orbiting GPS satellites, DGPS beacons are fixed land based devices.
When there's no DGPS beacon, the unit automatically reverts to the regular and slightly less accurate GPS.
May 19, 2010 | Northstar Explorer 550 GPS Receiver
Alternative to Leica Laser Locator
Leica locator with DGPS capabilities? Leica still manufactor advanced military systems under the Swiss brand name of Vectronix which is part of the Leica group. Are you after a laser locator or a rangefinder such as the discontinued 7x42 Geovid. The Geovid is still available but no longer has the electronic compass. The original never did connect to a DGPS PC only the Leica Vectronix Vector could. None of these models will locate a laser only use a laser to calculate distance. Current Geovids range to 1200 meters and the Vectronix 21 will range to 12 Kilometers. Unless you are a certified government customer the Vectronix 21 you will not be able to purchase. Newcon have models that allegedy exceed 2000 meters that are made in Russia and depending on the model can be had for a few thousand dollars. The Leica Geovid 8, 10 or 15 power can be had for around 2.5 thousand to 3 thousand dollars and is an excellent robust unit. It will not connect to a PC for GPS sync though.
Mar 12, 2009 | Leica Laser Locator Binocular
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from www.garmin.com
enter: www.garmin.com
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
regards
frankie
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Nautilus problems
Hello:
I also have the Nautilus & the processor just isn't as fast as the newer units. You can adjust the track up mode to only refresh when the rotation of the map is over a cert amount, degrees, (resloution angle) if you have it set to a low value it will continually keep the route dead up & constantly refresh.
See section 4.3 Map orientation in the manual.
On the route reversal are you getting the pop up screen that alerts you that the route has been reversed?
I assume you have a manual?
I am actually contemplating selling my unit as I have a Garmin 478 from work & the screen is much easier to read in the bright sunlight. I had my Sitex on my Grady which had a bimini, but my Mako CC does not & the sunlight washes it out.
I'm thinking $375 for the whole unit with a wide area chart of MA.
May 14, 2008 | SI-TEX Nautilus NT GPS Receiver
WAAS
sounds like the problem is with the pilot. You may be expecting too much from nav mode you should check the antenna connector on the WAAS issue
on VX2, are you marking a good bottom on the sonar screen, but have no digital overlaid? never seen it, must be a BB thing
May 04, 2008 | Furuno GP32 GPS Receiver
Garmin GPSMAP 76Cx GPS Receiver Logo
163 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
