Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
Picture looks like photo negative when power is reapplied
When I turn the TV off and then go to turn back on now matter how long of a period of time the TV has been shut off when it is first powered back on, the picture looks like a photo negative. It takes as long 4 to 5 hours to warm up before normal picture returns.
  • rccline Feb 02, 2008
    The model # for TV is listed above. It is several years old.
    Hope someone can help, this is a great site!
    Shammi174 - thanks so much for your feedback. Yes, my set is probably 1st generation has this has been a nuisance for several years now. I pretty much never turn it off because of this issue. How do I refresh rate?
    Problem Solver:
  • 5 Answers
The most probable problem is it would be one of the first generation LCD televisions.
if possible try changing the refresh rate of your tv
it may help.
Posted on Feb 02, 2008
  • David Mathew
    David Mathew Feb 02, 2008
    in the setup menu of the tv go to the picture setting the refresh settings would be mentioned and set th refresh to the maximum
What part needs replaced when the picture looks like a photo negative?
T'Con board fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 08, 2015 | Samsung 6350 Series UN55F6350 55" LED...
Sharp 52" LCD-Negative picture
hi bring the menu up if it's the same as the picture, the mainboard could be the problem, also can be a bad panel thanks
shaun
Mar 04, 2017 | Televison & Video
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
After the tv has been on for about 30 minutes the picture starts flickering really bad and eventually will go completely white like where it looks kind of like negatives? it works perfect for that first...
The colors wheel could dies at any time of the tv life,at any monent without any period of times.The colors wheel run at RPM spinning revolution are 1000 RPM a min. to make colors for this tv.The problems u discribing are one problem of the effect of the colors wheel is dying and worn out.The colors flashes like film negative,the picture flashes Black&White withtin the picture.Replace the colors wheel again,will solved this problems.
Nov 20, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Picture turns into looking like a reverse negative
Often you will get a bluish or reddish looking picture if your wires from your cable box/satellite or DVD player are inexpensive RCA type video cables. Try using a nice set of component cables or HDMI cable from your sources to your TV. If this is your setup, try this first...its the most inexpensive first option.
Dec 31, 2007 | Hitachi 36UX59B 36" TV
KV35S42
Classic bad picture tube! End of natural life for that make/Model.
The  current sensing circuit is turning the video on/off.
The orangey look also indicates CRT no good.......T.
Oct 20, 2007 | Televison & Video
TV won't shut off
Sounds like color wheel BP96-00250A. Have installed by professional $350 ish
Aug 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
2,231 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
