Question about RCA VR636HF VHS VCR
Wont work every time i try to turn my vcr on it just says safe on the display and wont do anything
  • 579 Answers
Reset it by unplugging the power briefly. If that doesn't work, then it is detecting a mechanical problem inside and needs to be repaired.
Posted on Feb 02, 2008
Why wont vcr work after new belt. mode a waste of time
Whenever you work on a VCR, or the mechanism goes faulty, the mode switch - which tells the electronics what mode the mechanism is in - has to be set up correctly. This is a very complex procedure and unless you have done it before you will need a service manual. Mostly because the mechanism is rarely ever set up in eject mode. At the moment you VCR is trying to work out what mode the mechanism is and is trying to eject a tape, when the mechanism has already done so!
Feb 01, 2016 | Televison & Video
Vcr keeps saying safe
Try this: (actually found in user manual...)
Pro-Tect Plus™ (Child Lock) Feature
This feature is useful to tamper proof your timer recordings from unwanted changes
and/or protect the VCR from mis-operation by other users in the household.
To Lock the VCR
Press and hold POWER or VCR on the remote for
approximately six seconds to turn on the Pro-Tect Plusª
feature.
SAFE appears in the VCR front panel to let you know the
feature is activated.
To Unlock the VCR
Press and hold VCR button on the remote for approximately
six seconds to unlock the VCR.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 27, 2009 | RCA VR355 VHS VCR
Safe!!!
Go inside and REPLACE e v e r y rubber band that u find in machine. Don't replace one or two, if you find one or two bad
REPLACE THEM ALL.
May 23, 2008 | RCA VR355 VHS VCR
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
VCR stuck on menu screen
Thank you. I did fix the problem. Reviewed the instruction manual for the Samsung VCR and removed the SAFE reading on the VCR by just holding down the TV-VCR button on the RCA universal remote for several seconds which then released the frozen menu screen. From there I was able to reprogram the TV using the instructions and codes for the RCA universal remote. I still have to reprogram the VCR.
Mar 09, 2008 | RCA Universal Remote Control
Govideo VCR and DVD player just stopped working.
"ChildLock" is on... You must turn it off using the remote. There is a button on the remote called Childlock
Nov 24, 2007 | GoVideo Go Video DVD/VCR Combo
Vcr will not work
Try pressing down the vcr or Aux button for a long time. Then try pressing down power button on remote for a long time. Try info or display button for long time. After I fiddled around with these for a long time it worked.
Sep 29, 2007 | RCA VR355 VHS VCR
SAFE
Hold down the power button (or the vcr button if on a combination remote) for six seconds. This will unlock the child lock feature of the vcr.
Sep 06, 2007 | GE VG4060 VCR
My VCR is in Safe Mode
Hello Mark352, What model of VCR do you have? is it a GE In the mean time try this: Unplug it from the wall for about a minute and then plug it in again. If this does not work, hold the VCR button down for 5-8 seconds this works on some units. Let me know if this works for you. Thank you,
Aug 26, 2007 | GE VG4270 VCR
Safe
There should be a button on your remote labeled "safe." Press that, and it will turn the safe mode off. It's on the second row from the bottom on my remote.
Jul 15, 2007 | Sanyo DVW-6100 DVD Player/VCR
Televison & Video Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
