Speaker capabilites Hi! could you tell me the manufacturers recommendations for the maximum volume on the product below. Volume displayed on the screen go from 0 to 100.
  • thedeadthing Mar 21, 2008
    I am trying to hook up an sorround sound system to my Proscan 26la30q
    Scholar:
  • 70 Answers
The easiest way to determine that,is to slowly turn up the volume until you hear the speakers begin to distort,whatever setting they distort at,should be the highest under any circumstance that you turn it up for,otherwise you could overheat the output IC's or the preamp IC
Posted on Jun 10, 2009
    Sergeant:
  • 261 Answers
I would say between 75 & 80. Or better yet, Just as it starts to sound distorted, then turn it down just a bit until it sounds good again. Clear i mean. Also if you want more volume out of that or you need it louder for whatever reason, you can hookup the output of the television to an Audio Receiver and turn it up extremely loud. Rock and roll. Good luck. Guru Jay
Posted on Feb 02, 2008
Nordic Track T9.1 INCREASE speaker volume
reset the treadmill, and try again.
However you must read your owner manual, download from
www.fitness.manualsonline.com
God bless you
Jul 29, 2013 | Exercise & Fitness
I can't turn up the volume n my laptop
Which operating system ?
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers. These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop. If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse.
Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control. Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting. Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume. Be sure the speaker icon below each control is not accidentally muted. Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio. Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar. Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category. Hope this helps
Dec 10, 2012 | Acer Aspire 7741z-5731 17.3" 1.86ghz P6000...
Sound (volume) of media player is at maximum but still very soft.
Go to your volume control via Control Panel or double click on speaker icon on task bar and check sound settings and computer volume or check your speaker's volume. Otherwise your speaker at fault.
Aug 25, 2011 | Computers & Internet
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
Ihave purchase of emachine note book of acer. volume of the speaker is so low hat even one person can not hear.i have talk with service center of acer,but they told that this is a maximum volume of the...
I have had that laptop once and had the same problem. I knew that it was the maximum volume of the speaker so I purchased external USB speakers to connect to the computer and the sound was clear and loud enough to hear anything played on the computer.
Thanks
P.S. Please rate if this solution was helpful
Nov 01, 2010 | Acer Computers & Internet
The sound on my computer went away, The volume is on maximum.
Please check for the speaker pins properly inserted and just restart the system once. if the problem is not yet solved, reply back.
Thanks
Thahir.
Feb 28, 2010 | Audio Players & Recorders
CANNOT FIND UNLOCKING CODE FOR VOLUME LIMITER ON IPOD CLASSIC BLACK 120GB
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jul 15, 2009 | Apple iPod classic MP3 Player
Protected
Oct 23, 2008 I have the same "Protector" problem. There is mention of this on Sony's website:
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
I followed their "advice" to troubleshoot...now my unit's been in the shop for a couple weeks.
I called for status today 10/24/08 and was told that there is a "backorder on a part". My repair
shop cannot estimate when the "part" will be available.
SO...I suspect a component failure and since Sony does not have the part, the questions are:
1. Is there a delay in Sony getting the needed part from the manufacturer (if it's not Sony)
2. Are there so many occurrences of this problem that Sony can't keep the the "fix part" in stock!!
Time will tell!
Dec 02, 2007 | Sony STR-DE935
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
