Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
HDMI crap out
By josephus1 on Feb 02, 2008
I have an Olevia 232V that is firmware upgradable. Did an upgrade and now have no HDMI (no signal) shows on TV. Before upgrade TV would come on and say (no input) for a couple seconds then, picture would come on. Have a FIOS Motorola stb and called verizon out. They said there is a compatibility problem between the stb and TV and are working on a fix. If that is the case, why did my HDMI work in the first place before the firmware upgrade. Now back to component cables.
Same Problem
Jan 08, 2009
-   Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have owned a LNR3228w for almost three years now and I have had problems with the HDMI input signal x 2times. I got it fixed at Eltek since I was still in Vision's 3years warranty. Without the warranty, it would have cost me around $500 to repair it. However, just about 3months before my warranty ends, I found the same problem with my AV1, AV2. It is again, not picking up signal from the cable. It is getting frustrating now, I called Samsung, Vision and Eltek... but I already know the only thing they will tell me to do is bring it back to Eltek for repair. Even though on the 3year warranty plan said Vision can replace a similar product if they can't fix the problem. I call Vision up, they told me is been too long and they can't exchange for a similar item or help me with it, even though I am still under the warranty... I can bring it back to Eltek and get it fix for now but I know the same problem will happen again for my LCD TV and I will not be able to use those function (watching DVDs, HDTV) on this TV.
-   shuratt
Jan 06, 2009
-   I have an Olevia 332-B11. I just got a home theater and have had my tv for almost two years. I've never used HDMI inputs, and can't get it to work no matter what I do. I smell class action... -   dovs13
Feb 23, 2008
-   I'm having the same problem. Just did the upgrade thinking I was being smart before we have a movie night tomorrow night . . . and now my HDMI input to my Scientific America box from Time Warner won't show anything except for the tv's NO INPUT signal. What the heck?-   BadgerKyle
Feb 18, 2008
-   I have had my Olevia 32" TV for 4 months now. I just lost the HDMI feed to my TV. I checked my Verizon FIOS connection. After swithing to a cable output on the STB, I could get a regular signal to my Olevia. So, the STB is getting a feed. Therefore, I don't get the HD signals.
I am hoping it is just a compatibility issue or just a bad HDMI cable.
Let me know what else I can check on my own.
Bill-   Guest
Best Solution
posted on Feb 26, 2008
Helpful)
BadgerKyle
Rank: Apprentice
Rating: 85%, 2 votes
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Was this helpful?
Yes
No
Solution #2
posted on Feb 26, 2009
Not Rated)
mattaww
Rank: Apprentice
Rating: 0%, 0 votes
I finally found a Verizon tech person that knew how to fix this problem. I had the same issues, especially when running an all-HDMI signal and switching to standard definition signals from high definition signals.
The tech explained:
"With your set top box on, and while you are receiving a signal, you should be able to see a new menu pop up on your TV if you press the buttons on the front of the STB in the following order: Power - Select - Menu. Third item down from the top is something called 4:3 override. Change it from the default (probably 480p) to 480i or stretch, or whatever it takes to change it from what it is. Power off the STB, and you should be able to switch channels fine"
It worked!
Was this helpful?
Yes
No
Solution #3
posted on Aug 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey guys, I've got the same issue with an Westinghouse and Verizon Fios box through hdmi and I was able to fix it by unplugging the Fios box for about a min or two and then plugging it back in. I don't know if that will help everyone, but I think thats gonna be what I do first.
Solution #4
posted on May 02, 2008
Not Rated)
Lilybelle
Rank: Apprentice
Rating: 0%, 0 votes
I have Verizon FIOS with my new (less than 6 months old) Sony TV and an HDMI cable. Last night in the middle of a show, for no apparent reason, the TV showed "no signal". I called Verizon and they said this is a "known problem" with HDMI cables to TV's. They tried disabling my STB and then turning it back on. This did not work. They suggested I get component cables. This makes me really angry. If they knew about this problem, why didn't they tell me before I hooked it up? Also, it worked fine for 6 months and now it doesn't, and they said yes that's how it seems to go. They are working on a fix for it, and I can call the billing department and ask for an adjustment. I am wondering if Comcast would like to buy out my Verizon contract.vWho has time to go buy new cables and mess around with all this stuff?
Was this helpful?
Yes
No
Solution #5
posted on Apr 13, 2008
Not Rated)
81mustang
Rank: Apprentice
Rating: 0%, 0 votes
same thing for me. I have FIOS with the motorola box and my father was telling me I should upgrade because their seem to places when watching HD that the picture would skip. So I did it and now my HDMI wont work. The weird thing is I also have my upconvert dvd player connected through a HDMI switch and after leaving that trying to connect for like 5 minutes it actually connects. Olevia has to fix this problem.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
how to unlock sansui channels
Answer
how to unlock channels
Answer
picture is dark kinda red, and the buttons dont operate the menu options
Answer
I have an Acer x223h hooked to a Macintosh usgin the DVI-D cable. The display has been in place... (More)
Answer
i recently try to connect my labtop to my plasma tv via hdmi cable. i connected my cable to my tv... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
