Question about LG WM-2277HW Front Load Washer
Error Message What does the UE error message indicate?
    President:
  • 1,294 Answers
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Would be good if you mention which part of the globe u r from.....& rate me if helped. U cld post back for further help.
Posted on Feb 02, 2008
What does"ue " mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung WF337AA Front Load Washer
What does "ue'"mean?
Jun 29, 2011 | Samsung Washing Machines
I get a message le or ue error and machine stops
Where in the cycle is the machine stopping?
A 1E error would be a fill problem. Either the water supply is inadequate (low pressure coming in due to a problem with your water supply), the water supply taps aren't fully open (make sure to open the valves fully), the inlet hose is bent (straighten the hose) or the inlet filter is clogged (clean the filter).
An UE error happens during the spin cycle. Either the load is too small or the load is uneven. Add some items that can tolerate the spin cycle speed or redistribute the load.
A LE error indicates that the motor has overloaded. Wait 30 minutes and then try to restart the machine. If the error persists, the unit needs service.
The manual for the WM-2277H* is available from LG as a DjVu file here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=WM2277HB&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WM2277HB&initialTab=documents&targetPage=support-product-profile# .
I hope this helps.
May 30, 2011 | LG WM-2277HW Front Load Washer
Error code "UE" clothes have
UE = Unbalance Error
Thanks for using FixYa !!
Dec 12, 2010 | Washing Machines
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
Error message UE is displayed and the machine has stopped
UE means unbalanced load. This happens when the load is too small, or the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Jun 16, 2009 | LG WM-12230FB Front Load Washer
Error message UE
out of balanced? adjust your clothes till there even around the bowl. set the machine on a higher water level. cheers
Mar 31, 2009 | LG Washing Machines
Samsung frontloader problem
UE - UNBALANCE ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Washing Machines
Letters UE on display
Jan 26, 2009 | Washing Machines
LG WM-2277HW Front Load Washer Logo
139 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
