I am a ac tech, and i was working on a old carrier unit, wich had no schematic diagram. I need it in order to get the compressors going. if i give you a model # can you please provide one.
  • Anonymous Jul 28, 2008
    schematic diagram
  • Gary Davd
    Gary Davd May 11, 2010
    What is the Model# ???
  • 86 Answers
Mail me wht is yr requirement
1 compressure.
i can send u wht ever u want
mintex007@yahoo.com
Posted on Mar 16, 2008
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Hi: I have a Carrier 38CMC42300 AC unit which will not turn on and the air handler is blowing hot air. The 40 amp breaker for the AC unit trips right away when reset. Could this be a condenser or motor...
Your compressor or the start components are bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 30, 2010 | Carrier 38CKC036 Air Conditioner
My carrier 38ckc036350 is 6 years old. Today the compressor stopped working. The fan outside comes on and every few min i hear an electrical buzz like the compressor is trying to be energized. Are there...
Hi!
It sounds like the capacitor and/or compressor are quitting. Try getting a Start Capacitor of the same uF (I think 35 uF for Commpressor and 5 uF for fan motor) as the one you have, OR get a Start Kit from any AC parts shop for about $10 and hook it up in line with the old capacitor, if you have a two terminal capacitor plug the terminals one, on each end, if you have a 3 terminal called DUAL Capacitor, each terminal is stamped with the words FAN, HERM and the letter C for common, one lead goes in the C terminal and the other one goes on the HERM.
Install it and turn unit ON. Good Luck!! Don't forget to rate this post!!
Aug 20, 2010 | Carrier 38CKC036 Air Conditioner
Looking for a parts list/owners manual for an old carrier AC unit. Model #38 REO 36 300. Any idea?
Follow this link to the search page for the Unit need need literature on. If you want to change models (i.e. from the 38BR to the 38RE, both of which you list in your question), just enter the 1st 3-4 characters in the search box. this link is for the 38RE. Good luck!
http://www.commercial.carrier.com/commercial/hvac/technical_literature/1,3063,CLI1_CNT1_DIV12_ETI9039_MID4442_QRYY,00.html
May 27, 2010 | Carrier 38BRC036 Air Conditioner
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
May 11, 2009 | Carrier 38CKC036 Air Conditioner
I am a ac tech, and i was working on a old carrier unit, wich had no schematic diagram. I need it in order to get the compressors going. if i give you a model # can you please provide one. roof top ac...
you aren't an ac tech number one but i shall overlook that . your question is llike will the sun come up in the north or the south tomorrow. obviously in the east as it has since the earth was created. anyway. all compressors since the beginning of time wire up the same .a wire commonly referred to as the common goes from the contactor to the compressor. usually black in color, hence the old coloqualism Blacks are common. the run wire is from the contactor to the run side of the run capacitor or from the contactor to the run connection on the compressor. hence the old slogan reds run when you point a gun at them. the only wire left is the start wire that come from the start capacitor and is usually yellow . hence the old saying blacks are common, reds run, and yellows are always starting something. very ethnic i know but thats how i was taught.now that the wirings correct check to see volts through contactor are correct and if one side of contactor is not feeding. if volts good then check capacitors with a cap checker. if all else looks good kill power and inspect compressor terminals at compressor. if burned off consider a termilock kit good luck..
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
209 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
