Question about Kroy K 4350 Printer
Shrink tube. hi. my name is luis i bought printer 4350...how i put the shrink tube in the printer do you have example in user manual o picture? size of shrin tube 1/8 ..1/4
    Problem Solver:
  • 15 Answers
I guess that by now you have figured this out. If not, email me at hanover@visi.net and I'll email you a copy of the manual (.pdf format). We're Hanover Technical Sales, Inc. We do Tech Support on Kroy machines.
Posted on Oct 03, 2008
Como poner el hilo en una singer merrit 4350
Download the user manual free at the Singer site under support -- it will show you with pictures how to do this.
Jun 24, 2017 | Singer Sewing Machines
When I calibrate the Kroy K4350, it cuts off all of the material (about 1 foot) after it finishes calibration. This will get costly as we use the printer for heat shrink tubing and change sizes of tubing...
It appears that your printer has the cut bit set to cut, from a prior print job. Suggest that you do a short print job with the cutter set to NOT cut. That should change the instruction in the machine until it has been changed to cut again. By the way, the factory advises us that the K4350 should typically NOT be using the cutter to cut heat shrink. So you may want to change the setting to NOT cut for the long haul. If this does not solve your problem, you might give us a call. We're Hanover Technical Sales, Inc. We're a premier Kroy Dealer. Call (757) 357-2677 and ask for Don.
Oct 31, 2013 | Kroy K 4350 Printer
Cant upload video just cause 2 on ps3
hi i am asadshah i am the one who right this question i found the solution that is you go to you tube account and see on the top what ever you tube calls you (example you tube calls me asadsha) you write your account name on the paper and make just cause 2 video and try to upload it on the user name put your account name written on the paper and put your account password and try to upload it i now that it will work (reply)i asadshah671@yahoo.com ) if it work
Nov 25, 2012 | Video Game Consoles & Games
I have a visible wiring breakage as the wires emerge from the pump. Is this something that can be DIY repaired? Or should I replace the entire unit? Little Giant Tools-Products - 5 Asp Submersible...
Hi acaffey7701...
You can repair it if you want to.
It can be done by skinning back the wires, cutting the wires,(give yourself a few inches of wire )slipping over the wires some heat shrink tubing the correct size for the wire, then sliding it out of the way, solder the wires back together, put the heat shrink tubing back over the bare wires and heat with a heat gun till it shrink fits around the wires. Then take black plastic electrical tape and tape the wires back together till it is almost the same size as the uncut electrical cord. After you have the wrapping of the tape done then you will get a tube of silicone sealant and put some of the sealant on the taped surface you just finished taping. Spread the silicone sealant with your finger and put it on the taped wire heavy.Let it dry and your good to go.
Or Replace the unit.
Please take time to rate me
Aug 30, 2011 | Little Giant Tools-Products - 5 Asp...
Trying to print on heat shrink tubing, but will only print one then jam up in the printer lighting the error.
Your software is probably set to print labels with gaps. We're guessing that you need to reset Document Properties to Continuous. If that does not solve the problem, we're Hanover Technical Sales, Inc. Give us a call at 757-357-2677 and we'll help you thru the problem. Ask for Don
Jan 25, 2011 | Kroy K 4350 Printer
HI, I was wondering if there is way to adjust the horizontal position on the screen of Sony KP-57WV600. By adjusting I mean a way to shrink the displayed picture horizontally or vertically.To give you an...
There is button "Wide Mode" on tv remote, press it repeatedly to select desired zoom mode to view best fit picture in screen.
Click Sony Support link to download user manual free copy and check page-48 for details.
Thanks.
Jan 06, 2011 | Sony Televison & Video
How do you install 3/8" shrink ribbon into Kroy K4350 so the writing is centered correctly?
The issue is not how you center the tube, most likely. It's in how you set it up in your software. Give me a call, toll free at (800) 304-9043. I'm Don at Hanover Technical Sales, Inc.
Nov 18, 2009 | Kroy K 4350 Printer
Broken Kroy 4350?
You may have the tube threaded over the green sensor board, instead of below it..
What size tube is it. 1/8 and sometimes 3/16 lets infrared light past one side or the other and trips the sensor, making the machine think there is no tube in there, also.
We're Hanover Technical Sales, Inc. We do Technical Support for Kroy machines. If we're wrong, we don't have enough info.
Jun 10, 2008 | Kroy K 4350 Printer
Need help with Kroy K4350 Printer.
This sounds like a hot pixel failure on the print head. The hot pixels are not repairable. The entire head will have to be replaced, most likely, at a cost of about $300. Hanover Technical Sales, Inc. (that's us) does Technical Support for Kroy printers, so we know what we're talking about.
Could it be something else? Sure, but without a pic of the issue, we'd not be able to guess what else it might be.
Make sure that heat shrink tube is clean and free of static electricity. When possible, use Kroy brand tube in the K4350. And we have a new hybrid ribbon that minimizes static at the head ... and consequently minimizes hot pixel issues.
Dec 12, 2007 | Kroy K 4350 Printer
350 people viewed this question
Top Kroy Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Kroy Office Equipment and Supply Expert? Answer questions, earn points and help others
