Question about AOC LM729 17" LCD Monitor
My LM729 will power on, I see the splash screen, then it goes dark and flickers like it is trying to come on. The power light is blinking. If I leave the monitor unplugged for a few days and they it again it will come on, but the first time it goes into sleep mode it will not wake back up. That's when the screen flickers and the power light blinks again. Can this be fixed easy?
  • SeaFox236 Feb 02, 2008
    Where can I get the inverter? Thanks.
  • Anonymous Feb 18, 2008
    I had the same problem. The monitor splash on start and turns off. It cause because missfunction of +12V pin5 on CN11. I changed C922 on inverter board.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AOC Master
  • 848 Answers
AOC LM729 17" LCD Monitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
Posted on Dec 23, 2014
The guy with the with the capacitor suggestion is right. i had tried re-soldering the coils with no luck. i then found this post. i checked the c922 capacitor. the top of it was swolllen. the rest nearby were flat. i found one in an old peice of electronics equipment i had laying around and replaced it. monitor now powers up and works fine. i would suggest using a new capacitor. however, this is sunday and no local electronics stores are open. :)
Posted on Mar 02, 2008
    Sergeant:
    Habit-Forming:
  • 194 Answers
The inverter needs to be replaced
not real hard, but must have some knowledge of the process
Posted on Feb 02, 2008
  • kj henriksen
    kj henriksen Feb 02, 2008
    i usually troll ebay.
    it may take awhile to find one.
    the manufacturer will have one
6ya staff
SOURCE:
Aoc monitor power button will not turn on
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | AOC Computers & Internet
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
(external monitor AOC LM765 flickers white lines) My laptop screen is damaged. I plugged an external monitor (AOC LM765 via RGB), works fine for the past three days but suddenly ghostly lines appear. Any...
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
May 15, 2011 | AOC LM765 (Silver) 17" LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Blue screen flickers and goes almost completely dark... when i plug into a different monitor, everything on that monitor is clear, so i know the compputer itself is fine. How do I check for a loose
most likely inverter issue, or somewhere in between inverter and LCD, illumination bets thing to do is to take aprt the LCD frame and disconnect and reconnect all wires leading from the inverter. If that doesn't work, the replace the LCD wires and or inverter.
May 20, 2009 | Acer Aspire 5100 Notebook
AOC LCD Screen (LM726) Flickers on then off
Well with my experience when an LCD monitor does that it usually is something in the power board on the inside. If it is still under warranty I would suggest getting it RMA'ed back to AOC. Here is the page where you can start the RMA process with AOC.
http://www.nam.aocdisplay.com/aoc/index.html
Just click on USA RMA Request form, then click you agree, then fill out the form and then submit. They should get back with you pretty quick.
Hope this helps, and don't forget to rate.
Feb 28, 2009 | Intel Motherboard
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Aug 15, 2007 | AOC LM729 17" LCD Monitor
Monitor picture goes extremely dark
sounds like the backlight is defective. You can probably get a new backlight online if your comfortable taking apart sensitive electronic equipment BUT you must be very very carefull and handle the lcd with care as you can easyly damage it. Oh one more thing the power supply may also be defective for the backlight. I would contact the manufacture to see about the repair or replacement parts as they should be listed in your operators manual. Good Luck
Apr 22, 2006 | AOC LM-727 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
803 people viewed this question
Top AOC Computers & Internet Experts
Ekse
Raj Patel
dannydoesita
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
