Question about Jetway 939GT4-SLI-G Motherboard
DRAM Beep I had a problem with my old motherboard not being able to support my new video card, so i upgraded my mobo to the Jetway 939GT-SLI-G model. The only new thing I added was a new video card, so I am using the old RAM, CPU, and power supply. I know everything turns on- or at least lights up and all the fans are working. But it will not load anything. I have tried to look in the manual- but it isnt clear. Do I have to reset the CMOS before I try anything else?
  • 3 more comments
  • LostWolf1 Feb 02, 2008
    It gives one long beep. Also the Debug Port reads "C1" all the time.
    Does it matter that both the motherboard and video card are brand new?
    Another question- do the chipset(s) in both the motherboard and the video card have to be the same in order for them to work together? I noticed the motherboard has a "nForce™4 MCP SLI Single Chipset " but my vidoe card does not- it has ATI (manufacturer).
  • micromaster
    micromaster May 11, 2010
    Does it gives a long beep or a short three beep?
    tnx
    -micro
    Brigadier General:
  • 3,614 Answers
Try to clean the bronze circuit of your VGA card and insert it again, if its the same Your video card is broken, you need to replace..
1 Long beeps means theres an error on your vcard / or theres a problem on it..
3 short beep means thats your RAM have an error or a problem on it..
Once the if the mbord doesnt gives any sign or a beep and seems to be blackout there could be a short circuit on your mbord to the parts with a connection to it...
Posted on Feb 02, 2008
I was wondering if my 939GT4SLI-G can run PCI Express 2.1 x16. Example of a video card would be, MSI R6950 Twin Frozr II OC Radeon HD. Thanks, Rob
This is your board:
http://www.dealtime.com/Jetway-JetWay-939GT4-SLI-G-Socket-939-NVIDIA-nForce4-SLI-ATX-AMD-Motherboard-Retail-939GT4-SLI-G-BRAND-NE/info?sb=1&tab=specs
This is the card you want:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575&nm_mc=OTC-RSS&cm_mmc=OTC-RSS-_-Desktop%20Graphics%20%2f%20Video%20Cards-_-MSI-_-N82E16814127575
Some say that the card will work but with limited capacity. I don't see the power requirements for the card but, I would guess a minimum of 350w or greater. Your board definatley was not designed for this card. It's alot of money for a card that may not work at all with your system.
This is MSI's link:
http://us.msi.com/index.php?func=prodvgaspec&maincat_no=130&cat2_no=&cat3_no=&prod_no=2093#menu
There is a "contact us" link at the bottom of the page where you can try to ask them but, in my opinion, for the money, I don't recommend the card without upgrading your system.
Dave
Jul 01, 2011 | Jetway 939GT4-SLI-G Motherboard
I have am2n-e sli mobo, amd 5200+ 64bit dualcore cpu, 4x1gb ddr2 ram sticks, gf 430gs pcie video, 500watt psu, 2x ide and 1 sata hdds, and a ide dvd burner post check beeps one long then two short, with...
The one long-two short beep code is for bad memory, not for a failed video card.
Shut down your computer, remove one stick of ram, reboot the computer, and repeat for each stick of ram, until you find the bad stick.
Feb 28, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
Can a Gigabyte K8N Pro SLI mobo support a PCIe 2.0 video card?
Hi Rachacha!
I have lait a few moths.
Off course, you can use the pcie 2.0 card on pcie 1.0-1.1 mobo, but the card effiency is only 90%, because the mobo have not enough power for the card.
Best regards
Kommy
Mar 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
Video card
This may sound weird, but remove ram to make it 2 gigs and try it again, some mobo's have issues with 4 gigs. 3 gigs usually works too.
Apr 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
7F debug code with no video output
do you see a bios screen at all or you just dont receive a signal at all?
Feb 13, 2008 | Jetway 939GT4-SLI-G Motherboard
No post no beep no video
you sure that the 4pin power connector coneected to your mobo
Sep 12, 2007 | Computers & Internet
When i boot Gigabyte K8N-SLI a long beep is heard untill completely booted
Long beeps can indicate a processor or board failure, but i would check your graphics card first, uninstall it in device manager and then remove and reseat the card. Although i think there is mobo failure imminent
Apr 23, 2007 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
New Jetway 939GT4-SLI-G won't power up
Try using the onboard video first, remove the video card and any other card from the motherboard. If it still does this, then check the memory, maybe the speed is not compatible. If it's not that then try booting up with the old cpu.
Apr 21, 2007 | Jetway 939GT4-SLI-G Motherboard
Jetway 939GT4-SLI-G Motherboard Logo
85 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
