Question about Whirlpool AWM8143 Front Load Washer
Whirlpool frontloader 6AWM8143
I press start to commence a wash cycle, the motor starts for about 3 to 4 seconds and then the cycle stops and the green "door open" light starts to flash. I'm not sure what this means.
  • Anonymous Mar 14, 2014
    The start/pause light and lock lights flash simultaneously when start is pressed. The cycle does not commence
  • 43 Answers
It's faulty contact the manufacturer or the seller
Posted on Feb 02, 2008
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
913T Dishwasher Stops after 10 seconds
913T is a very old model (1996), I have one, I'm not a repairer, I have the same fault. It doesn't have drawers or infrared or a display.
I've just shortened the ribbon cable, which had pinch damage at the door close pinch point. I used a male & female ribbon squeeze connector pair to make a good clean joint. With the cable fault it wasn't even starting the drain cycle. Now it does start, but then long beeps, and I suspect it's detecting a fault with the motor or a sensor or faulty wire, and is halting.
I've found running the rinse cycle first then allows the main wash cycle to run, no longer stopping at 10 seconds (after the initial drain), just as the first power wash commences.
May 24, 2012 | Dishwashers
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Whirlpool 6AWM8143 Front Load not starting spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
Determined the problem with my frontload Whirlpool Duet washer...the drain was definitely clogged. How do I reset it? Do I unplug it?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loadin washer says control locked!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet 9200 Washer door lock issue
no thiis is normal operation, it is considered a child safety feature. in case a sleeping child should happen to be in machine, the short 2 sec blast of cold water will wake them and give them a chance to exit before the machine starts washing.. all whirlpool frontloaders do this, thats how it waas explained to us at factory training.
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
333 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
