Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Unknown AutoLock on my Philips rear projection tv
I bought the tv of line and there is an autolock and it won't let me watch the tv, can I reset the factory settings or erase the lock somehow?
  • colima Mar 21, 2008
    my tv has autolock on av1 need access code to unblock
    model # 55pp95 0217
  • ibanezjo Aug 31, 2008
    We've had this tv for years and it's been fine. Suddenly a few days ago, random channels are autolocked. None of us actually set the lock so no one knows what the access code is. Is there a way to reset it?
  • Philips Master
  • 8,617 Answers
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Posted on Feb 02, 2008
My phillips television is locked
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philips sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Apr 21, 2011 | Philips 28PW6506 28" TV
Hi my TV has a picture of a padlock and i cant unlock it tried to use remote it wont work it is a magnavox 29inch
hi,
For unlocking you tv you have to reset its v-chip. Do the following for the same.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
ok
Apr 11, 2011 | Philips Magnavox 20MT133S 20" TV
I bought a used TV with an existing access code. I don't know the code and some channels are blocked. How do I disable the code? or reset it?
Hello
First disabel the lock and re-enter your own lock code. For this do the following.
OK.
Jan 10, 2011 | Philips Magnavox TS3260C 32" TV
What is the code for auto lock?
Hello
If your Philips TV is locked, just try this.
Ok.
Dec 11, 2010 | Philips 25PS40S 25" TV
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
The tv is blocked by autolock
I faced this same issue......the override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset. Good Luck
Apr 27, 2009 | Philips Magnavox 27MS343S 27" TV
Autolock on my philips magnavox 60p8342
I am sending the user manual to your email address it will explain the auto lock procedure.
Jun 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Format not selectable in AV-4
The AV-4 port on this TV is more problematic than anything I've seen. Set the resolution of the computer to 1024 x 768, 60 Hz refresh rate. If still nothing, set to 800 x 600, 60 hz refresh rate. Make sure the driver for the cable you have running from computer to TV is up to date. There's not much you can do on the TV end - all the changes have to be made from the PC.
Jun 15, 2008 | Philips 60PP9202 60" Rear Projection...
Philips tv with autolock
Check out page 14 of the manual.
If you don't have the manual click here to download:
https://www.p4c.philips.com/files/2/27ps55s/27ps55s_dfu_aen.pdf
Apr 02, 2008 | Philips 27PS55S 27" TV
New Used tv
Yes there is my friend! Follow these instructions and it will work for you! Philips and Magnavox: Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jun 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
