Question about EliteGroup P4S5MG/GL+ Motherboard
Jumper Settings I recently took apart my computer, Elite Group p4s5mg/gl+ because I had to reformat the hard drive. Now I have I took one jumper out to use on a dvd rom for another computer. I dont really know where I took it from but now my computer wont start. I turn it on and the cpu fan turns about a quarter way round and it does not start. I think it may be because of the jumper I removed, or the power supply is not working. I have had no problem with the power supply, So I assume it is the jumper. I would like to just find a diagram of jumper settings so I can get my pc up and running again. Help would be great!!!
  • newnum_c Feb 02, 2008
    I am actually talking about the jumpers on the motherboard itself.
  • 73 Answers
Hes ******** sorry about him u need to use pa for power see how it says that will go acorss only on jumpers not up down ok when u set that pa for power in try both ways to starys up then do idee then rreset dsame way start with 1st letter on mobo see how shows p that stands for power idd and rw or rs reset those 3 all u relly neeeed to get on ok to light it up mess aorund horznal not vertical ok start wityh p red then ove rto next pin cheak if not go to other pin on op side of it then test ok one willl light u up
Posted on Mar 14, 2008
  • 640 Answers
Are you talking about the jumper on the hardrive?if so if you have only 1 hardrive put the jumper on the 'cs' pins.if that doesnt work put the jumper on mas or (master).if you have 2 hardrives make sure the jumpers are on mas and the second drive on slave.hope this helps.let me know.cs means cable select
Posted on Feb 02, 2008
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Maxtor hard drive jumper settings for model 7245At maxtor hard drive jumper settings for model 52049h3
1. Jumper settings for model 7245At refer to LINK
2. jumper settings for model 52049h3 refer to LINK
Hope it helps.
Jun 22, 2011 | Maxtor Hard Drive
System can't find hard drive on main cable but it will run on the slave cable for the cd rom need to run on master how do i fix that? bryan thanks for any help
depending on your brand of hard drive if its western digital remove all jumpers and put on the master cable only, if it is alone,if there is another drive on the same cable then put jumper on master jumper which on western digital is in the center of the pin group,, your problem sounds like a jumper on the hard drive problem not a repair problem, i would look on the hard drive whichever brand and see jumper settings and make sure also that your jumper is good ,,,good luck I hope this helped
Nov 11, 2010 | Computers & Internet
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Only 32 gb of 250 gb hard drive is reconized
Hey,
If you look at the jumper settings on the drive, they are near the power connector and data cable, then look at the jumper info on top of the drive. I think the jumpers are set to limit space 32GB.
Adjust the jumpers.
Let me know if you need anything else.
Thanks,
Ekse
Feb 21, 2009 | Maxtor Hard Drive
I have a maxtor 90645d3 i need to make it my master drive...can u tell me the jumper settings plz
On the back of the drive you should see 3 groups of 2 pins. One probably already has the plastic jumper on it. They should be marked: m s cs. The m mis the master setting. s is slave & cs is cable select. Place the jumper onto the group of pins marked m & your drive is now set to master. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Maxtor Hard Drive
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
EliteGroup P4S5MG/GL+ Motherboard Logo
210 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
