Question about ASUS P5VD2-MX SE Motherboard
Cpu man error
Hi. i just installed a Zalman cnps9500 AT cpu heatsink/fan.
when i start up my computer, there is an error saying "CPU fan error"
On the manual for the fan, it has a section saying "Notes on Usage"
it states that "The operation of the PWM fan varies depending on the M/B setting. Please activate the PWM control mode from bios after installing. How do i do that? thanks for any help
    Genius:
  • 1,554 Answers
The first screen you see should prompt you to hit a key to enter the bios
such as f2 or del ( delete)
Posted on Feb 02, 2008
New system biuild won't boot to bios. Gigabyte GA-Ep45-UD3L Rev 1.0, Zalman CNPS9500, Intel Q8400, G.Skill 1066 2X2GB Memory, Radeon HD 4650 Graphics card,Antec Sonata III case w/ Earthwatts 500W PS. When...
ok well make sure you have the right ram look in the manual and see if it needs to be non error correcting or error correcting (non ecc or ecc) and if it needs to be registerd or unregisterd ram (AKA: bufferd and unbufferd Ram) dont run it very long with no CPU FAN or it will burn and check that fan by pluging it in someware els thats strange cpu fan is always running when mobo is on.
Feb 24, 2010 | Intel Motherboard
Zalman VF2000 LED fan starts then stops right after boot
Sounds like a defective fan, something having to do with the thermal probe, it causes the fan to speed up when cpu gets hot and to slow down when the cpu is cool. I suggest returning it for another one
Feb 10, 2010 | Computers & Internet
Overclocking heatsink!
I would suggest that you go for Thermaltake Duorb.
Even though its more expensive but it gives you a
perfect technology which keeps your CPU cooler
than your expectations.
Hope this helps you out.
Goodluck.
Feb 02, 2010 | Computers & Internet
Cpu cooling
The ZALMAN CNPS9700 is the best air cooler on the market.It looks cool and is quite easy to install. I have one in my box and I have 34 degrees with an Intel Quad core running 1 Gigahertz over stock.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
Nov 01, 2008 | Computers & Internet
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
Fan error
You mite not want to reset this. This could be telling you that your fan is faulty/Dieing. If so then if it doesn't turn off your comp, your CPU will fry from the heat. Try replaceing your CPU fan within your computer. "Cool Master" is a good brand. you can find them at any Fry's Electronics Store.
Oct 05, 2008 | Averatec Sotec 3200 Series Fan with...
Averatec cpu fan
IF you check your BIOS and everything is fine, and also you run a stress test, and everything clears. They you have no problem, usually you see this error in custom builds.
rate pls
Jan 19, 2008 | Averatec Sotec 3200 Series Fan with...
ASUS cpu fan required
CPU fan is supplied with the processor it self you need to contact your processor company
it you are talking abt the Casing fan then just get an ordinary casing from from a hardware shop
Dec 13, 2007 | Zalman Tech Zalman North Bridge Chipset...
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
ASUS P5VD2-MX SE Motherboard Logo
108 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
