Question about JVC VS-DT2000 CD Shelf System
Speaker switch box
Hi, I have sockets for outside speakers, which wire goes where? Do I split the inner/outer or left right, or both? Not tech (as you can tell) simple answers please. Thanks
  • dave5159 Feb 10, 2008
    Thanks, think I have it sorted now!
  • kurtjk1 Jun 21, 2008
    I have the rca 5 disc systen and I have hooked up my outdoor speakers for the summer. . when I paly the radio it works fine, when I play a CD only one speaker will work. any ideas?
    Novelist:
  • 124 Answers
Just to help clarify on this for future viewers:
There is a bank of 4 speaker wire sockets (2 pairs), like this:
[#][X] [#][X]
The # is black and the X is red. Each pair goes to one speaker.
The speaker wiring supplied with the system is copper in color, with two wires joined together. One wire has a black stripe on the clear casing, the other has no stripe. The one with the stripe goes into the black socket and the one without the stripe goes into the red socket.
With the unit facing towards you, lean over it and look at the speaker sockets on the back of the unit. The socket pair on the left goes to the left speaker and the socket pair on the right goes to the right speaker. Remember that this appears "reversed" when the rear of the unit it facing you, so that's why it's easier to do it oriented as I described.
Connect up the speakers and you're good to go. Don't forget to connect the sub woofer! It has a separate black wire with RCA style plugs. You plug it into the white colored socket.
Posted on Dec 24, 2008
    Scholar:
  • 44 Answers
Hi Dave. I guess it would be helpful to know model of the system. Could you send us the model number and make? If I have this information I can get you up and going!
Posted on Feb 09, 2008
  • Vern Eckel
    Vern Eckel Feb 11, 2008
    Glad to hear you have it figured out. if you run into problems let us know and we will try and help you as best we can.
95 Jeep Wrangler wiring harnesses broke down by color to show where each wire goes to
Car Radio Constant 12V+ Wire: Red/White Car Radio Switched 12V+ Wire: Purple/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Blue/Red Car Radio Dimmer Wire: Red/Black Car Radio Antenna Trigger Wire: N/A Car Radio Amp Trigger Wire: N/A Front Speakers Size: 4? x 6? Speakers Front Speakers Location: Dash Left Front Speaker Wire (+): Gray Left Front Speaker Wire (-): Yellow Right Front Speaker Wire (+): White/Red Right Front Speaker Wire (-): Brown/Red Rear Speakers Size: 4? Speakers Rear Speakers Location: Rear Roof Left Rear Speaker Wire (+): Gray/White Left Rear Speaker Wire (-): Brown/White Right Rear Speaker Wire (+): White/Black Right Rear Speaker Wire (-): Brown
Oct 04, 2016 | Crown Jeep Wrangler yj 95 94 93 92 91 90...
Need to repair a cut wire going from the left ear cup to the right ear cup
In fact the insulated inner wire (the white tube) is the signal carrying wire.
The outer wires without insulation are connecting ground (GND).
Both wires have to be connected to the speaker in the ear piece in order to (re-) build a circuit.
Jul 12, 2017 | Audio Technica ATH-A900 Professional...
How do i remove the inner fairing to fix a speaker
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Uninstall remove Install replace front fairing speakers on Harley Davidson...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 23, 2012 | 2000 Harley Davidson FLHT Electra Glide...
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
I have a Kenwood stereo receiver model k2 3600 , the left speaker keeps going out , the right speaker works fine. I've tried adjusting the speaker wire for the left speaker, and I always end up having...
HI,
BASED ON THE INFO YOU GAVE I HAVE SOME SUGGESTIONS BELOW..
1, switch the working right speakers cable to left output and problem left to right (from the back of receiver -not from the speakers it self..) to see if problem continues..
2.After switching them ,if it (old left new right one ) still stops left speaker cable may have short ( a tiny cable inner pieces may touching to other side ) at either at the back of receiver output or at the end ,at speaker input .
make sure you control it carefully...if the problem persist please contact to me..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 17, 2011 | Kenwood Audio Players & Recorders
2001 dodge stratus coup raido wire diagram
i split the diagram in two just prtin and paste. and please leve 4 thumbs up thanks
May 07, 2011 | Dodge Stratus Cars & Trucks
I need the factory audio color code diagram for a Chevrolet 2006 Colorado
2006 Chevrolet Colorado Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. The accessory turn-on is controlled by the lan serial network. Run a wire to the fuse box or ignition switch harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Apr 05, 2010 | 1998 Chevrolet Cavalier
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Jun 27, 2009 | 1997 Dodge Stratus
Speaker wiring
Here' s the colors to look for in the dash:
1994 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Antenna Trigger: Light Green/Yellow
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
Jun 03, 2009 | 1994 Ford Probe
I have a broken rca lead and dont want to pull the whole lead out of my car to fix it, i am putting some new ends on it but dont know how to tell which colours are earth
Depends which kind of RCA's you have.....Most likly you have sheilded where there is a center wire and then strands of wire wrapped around the outside of the insulation of the inner wire. That outer wire is the "Ground" the inner wire would be you right and left signals. Good luck.
-Andrew Hawkins
Apr 17, 2008 | Car Audio & Video
JVC VS-DT2000 CD Shelf System Logo
91 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
