Hotpoint First Edition FEW10P Front Load Washer Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the filter located on this washing machine?
Barry Coates
Level 3:
  • Hotpoint Master 3,463 Answers
  • Posted on Jan 11, 2010
Barry Coates
Hotpoint Master
Level 3:
Answers
3463
Questions
Helped
1405801
Points
12766
At the rear of washer.
Remove lower back panel.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Why does my washes sin and drain after wash cycle but not after rinse cycle
The pump filter might be clogged then for your washing machine or the pump filter is bad and will have to be replaced.the filter for your washing machine is located by the right side corner on a washing machine and coins or other debris or items maybe stuck inside of the filter.
Where is the filter located on an unidentified washing machine?
Inlet or drain-filter????
ow To Clean Your Washing Machine Filter - YouTube
? 2:43
https://www.youtube.com/watch?v=Mmvr4Xn2W1w
Jun 17, 2012 - Uploaded by Kenneth Watt
For more washing machine help please see our website at ... Far more helpful than the wretched manual that came with ourwashing machine. :) ... I just did this to my washing machine, the filter was blocked up with wool, ...
[PDF]Owner's Manual
shop.amana.com/assets/pdfs/literature/40068302.PDF
manual stays with washer. Contents. Important ... Keep this manual and your sales receipt together in a safe place for ... Amana Appliances offers long-term.
How to Empty and Clean Out Your Washer's Drain Pump Filter
www.homesavvyatoz.com/washer-drain-pump-filter/
Oct 13, 2011 - Do you have a front load clothes washing machine? Have you every wondered what happens to that spare change you occasionally forget to ...
Amana NFW7300WW Washer Locate drain pump filter
2answers
Clean filter washing macine
With any washing machine the filter is located at the bottom front and under flap unscrew plug.Beware water will come out.
Where are the filters on your washing machines I have an old 5100 6 cycle which has been fantastic and due for an upgrade in the interim hoping to discover where the filter is located
Hi just read your posting.Is this machine the 5100 Whirlpool front loader.If it is the the only filter on this machine is the drain pump filter.It is located at the bottom of the machine either behind the kick plate or behind a small door.When you locate the pump filter unscrew it anti clockwise and then clean it and replace. Put some towels down for the water that will come out from the machine.Please reply on how you got on.Looking forward to your reply.
5helpful
2answers
WMA46 washing machine not draining, filter blocked but can't locate filter
the filter is underneath on the pipe going to the pump, you wiull need to remove a hose clip.
Where is the filter on a Hoover softwave AC 270 washing machine
hi there,
here are top load washing machine parts are located.on figure 127dff9.jpgyou can locate where the filter was located,may be this will help you.,hope you can solve but if still not run,feel free to log in to fixya we are here to serve you better.have a nice day,rate my solution.thanks a lot.
4helpful
2answers
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
2helpful
Filter
take off rear bottom panel.
you will see a large diameter pipe going from bottom of machine to pump. take off this pipe at the machine end - careful, lots of water may come out.
filter is located inside this pipe. remove and clean
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
