Question about Panasonic PV-L750 Camcorder
Digital stills I need help as i am trying to display my digital still pictures on my laptop. I bought a serial to usb converter and ran the disk that came with it. I do not have the photoshot software needed to make the connection, it was tossed out with all our floppys. I have some precious pictures of my mother on this camera and would like to get them off as she has recently passed away. email me at daddyg09@yahoo.com
    Problem Solver:
  • 4 Answers
The panasonic PV-L750 comes with an 8 MB Compact Flash card for storing digital still pictures.
To remove this flash card from the camcorder, open the cassette loading area using the "Tape Eject" button. The card is located inside this area. Find the "Card Eject" button to remove the flash card.
You will have to purchase a USB compact flash card READER to view and/or transfer the pictures to your PC's hard drive. You can purchase one at any computer supply store, or buy one online if you like.
Once you've transfered the images from the USB flash card reader to your PC, you can view and/or edit them with your favorite graphics image editing software.
~app
Posted on Nov 15, 2008
I have a My Book which has a broken USB jack. I removed the drive from the case and would like to know if it's still possible to access the data on it. Smart tests detect the drive as OK, and it ran...
If the SATA-to-USB converter is working properly, then Disk Management should show the device, assuming that the disk-drive itself is working properly.
Dec 27, 2010 | Western Digital My Book Essential...
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Try a different USB cable.
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
Hi i bought a Z4mplus.. I have a laptop that only has usb ports and have connected the zebra with a usb - serial converter... however the computer installs the printer driver but wont send any information...
Make sure the serial port parameters match between the printer and the usb-serial driver. The Zebra printer is usually set to 9600 baud, 7 data bits, Even parity and 1 stop bit. The serial driver is probably different. The mismatch will prevent communications.
Hope that helps !
May 06, 2010 | Zebra Z4Mplus Label Printer
I need to connect my Lexmark X3650 to my laptop - but a standard usb lead doesn't fit. I need either a usb to usb connector or usb to 15 pin connector. Can you help?
hi: the 15 pins conector are display connector on laptops.
if there are posibilyti for pcmcia card you have a chooice of manny
usb /fire wire/serial/network/modem/ and so on or if the printer have centronics connection then you have to buy a usb to centronics thad wil also connectable to pcmcia card
Nov 01, 2009 | Office Equipment & Supplies
I need sabrent usb to serial converter drivers.The disk I received with my parches does not load!?
Try searching the following page
http://www.sabrent.com/#itemName=&itemID=0&section=Drivers
Feb 20, 2009 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Problem with an usb-rs232 adapter
There is a good chance the weak spot is your serial to usb adapter. The signals are not compatible so the adapter has a chip and serial driver to convert the signals. If the adapter is not fast enough to convert the signals, you get an error. Here is some more info on adapters.
5 Steps for Selecting the Right USB to Serial adapter
Mar 04, 2017 | Televison & Video
Need a USB converter for some serial thing
dynex puts out a usb to serial adapter can be bought at best buy for somewhere around 15.00 you will need the drivers from the cd to make it work and then will probably have to set the port it is looking for that should be all you need
Dec 05, 2008 | Toshiba - Floppy disk drive - external -...
Need driver for bf810
Dear Chandan,
You can download driver for your BAFO , from this site:
http://www.soft32.com/download_170532.html
Takecare and Be happy Always
Akshay
Sep 06, 2008 | BafoTech BAFO BF-810 Serial Adapter
What converter should i buy to attached my additional hard disk please show me
Am I right in thinking you want two drives on a single laptop IDE? (assuming due to the laptop picture displayed with your post). If so, I'd strongly recommend going with a USB external drive instead.
May 25, 2008 | Intel Motherboard
Connecting OPtio S4i to PC
After formatting my PC to upgrade it I've been unable to install the USB driver software to save pictures from my Tentax OPtio S4i to my PC.
My computer isn't recognising my camera when I plug it into the USB port.
When I've tried to install the Driver using the disk I got with my camera, at the stage where it asks me to MODIFY REPAIR or REMOVE, the software I get the following showing up on display boxes:
Aug 19, 2007 | Pentax Optio S4i Digital Camera
Panasonic PV-L750 Camcorder Logo
56 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
