Question about Pioneer PD-F1007 301-Disc CD Changer
Pioneer 301 cd player
I am getting error code UI and it won't move or do anything? what can i do to fix it?
  • 1 more comment
  • jon55555 May 13, 2008
    My Pioneer 301 cd player was moved and some of the CDs came loose. The result was the machine jammed and displays the U1 code. I took the top off and cleared the jammed CDs, but the problem persists - the carousel will not try to rotate, although I believe it is free to do so. I wonder if something breaks when the carousel jams?
  • slar676 Dec 03, 2008
    after moving, cds jammed and I get a U1 error code and the carousel will not move. I tried unplugging but nothing works.
  • Anonymous Dec 04, 2008
    I had the same problem. After moving and hooking it back up to my receiver/amp, I turned it on and tried to play a CD (to test that I had hooked it up correctly). It made an awful clicking noise as the carousel turned to pick the right CD. I turned it off, pulled the cover, removed all CDs and am now stuck with this error and a carousel that won't turn.
I found a fix in another thread. I tried it last night, and it worked. Nothing was broken; a moving plastic piece had just jumped out of its track. Here's the fix:
1. Remove the cover (2 screws on each side & 3 in the back).
2. Find a small white arm (more or less cylindrical, about 1" diameter, & about 3/4" long) and a longer (4-5"?) thin black arm in the center of the unit. These parts load/unload CDs to/from the playing area. You should see that a little knob on the white piece has jumped out of its track in the black piece.
3. Carefully put the knob on the white piece back in its track in the black piece. That should do it.
Posted on Dec 05, 2008
  • nancy mcknight May 12, 2011
    bless you Eric Carden!!!! thank you....this worked like a charm. It did take me a while of staring at it - there was a second black arm (with a spool in it) and i thought that was what you meant....then i saw the other black piece close to where the cds are - it was kind of hidden, but i moved it out and voila! there was a veritical **** that the white know popped into.....
    I know I should be upgrading, but i've been so happy with this that i hate to have to go tech.....
  • 53 Answers
I want to bless you also Eric Carden and thank you....this worked like a charm. It also took me a while of staring at it - there was a second black arm (with a spool in it) and i thought that was what you meant....then i saw the other black piece close to where the cds are - it was kind of hidden, but i moved it out and voila! there was a veritical part that the white know popped out of. Works just fine know.
Posted on Dec 13, 2011
6ya staff
SOURCE:
This is not a car dvd/cd changer. it is a pioneer f727 301 disc changer. I took all of the dvds out and reinstalled them, still no sound.
Check Your Wiring Harness On Back Of Player Also Your Stereo Sometimes Pioneer Tends To Get Loose Inside The Wire Harness plug.
Mar 17, 2012 | Pioneer DV-F727 DVD Player
The turntable is jammed does not rotate we have all the cd's out of it and an error code of UI comes up? any ideas how to get it to work?
May 30, 2011 | Pioneer PD-F1007 301-Disc CD Changer
My pioneer car stereo DEH-P77MP won't play cd's anymore. the radio still works, but on the screen it says cd error AO or A0. i was wondering what problem this code relates to? hope you can help,...
This is a common error with these units when they get dusty from putting dirty disks inside the drive. Just go to your local staples and or walmart and get a 5 dollar disk player cleaning kit. It looks like a plain cd but has small fibers that come out of the bottom of the disc that clean the laser as it spins and tries to read it.
May 09, 2011 | Pioneer DEH-P77MP CD Player
Error code UI when I turn it on
hit the thingymajiggermabob inside of it with a hammer than it shall work if not get a new one problem solved
Dec 18, 2010 | Pioneer PD-F1007 301-Disc CD Changer
The pd-f1007 301 disc player was working fine yesterday, and this morning i turned it on,, and the display didn't come on, and the tray just keeps spinning very slowly, any ideas
You may need to take the backing off of the player to check if any cds might have jamed in the actual cd player. i have one similar to this that jams because of one cd that is a little bit larger then the other.
Jun 21, 2009 | Pioneer PD-F1007 301-Disc CD Changer
Player displays -UI-
According to the manual: U1= "The disc may not be loaded properly in the rack." Countermeasures: Reload disc Check for foreign object on disc Check for foreign object on rack
Apr 07, 2007 | Pioneer PD-F1007 301-Disc CD Changer
U1 FAULT CODE
I had this same problem today.
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Feb 18, 2007 | Pioneer PD-F1009 301-Disc CD Changer
Pioneer PD-F1007 301-Disc CD Changer Logo
575 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
