Question about Panasonic PT-56WXF95 56" Rear Projection Television
The picture my tv is not using the whole screen. the picture is smaller. I hit a button on my sat. remote and its changed picture modes. How do I get it back>
    Scholar:
  • 84 Answers
Try the format button on the remote to see if it changes the picture size.
wg
Posted on Feb 02, 2008
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
The colours on my tv screen are all green and distorted can you tell me what the problem is its a samsung and its only 2 years old
YOU MAY HAVE CONNECTED THE RECEIVER TO AN INPUT ON THE TV THAT IS INCORRECT FOR THE SIGNAL OUTPUT FROM THE RECEIVER.
GET YOUR TV BACK ON THE CORRECT INPUT OR CHANNEL...CYCLE YOUR TV THROUGH ITS INPUTS BY...PRESSING THE INPUT, SOURCE, OR TV/VIDEO BUTTON ON YOUR TV REMOTE OR THE TV ITSELF.
IF THE PICTURE IS NOT RESTORED, CHANGE YOU TV TO CHANNEL 3 OR 4 USING TV REMOTE OR THE TV ITSELF.
IF THIS IS A 2ND TV, TUNE YOUR TV TO CHANNEL 60-73 USING THE BUTTONS ON YOUR TV REMOTE OR THE TV ITSELF.
ONCE YOUR TV PICTURE IS RESTORED, PRESS AND RELEASE THE SAT MODE BUTTON ON YOUR REMOTE TO ENSURE YOU'RE IN THE PROPER MODE FOR CONTROLLING YOUR RECEIVER.
YOU CAN ACCESS YOUR FEATURES, SETTINGS ETC, ON YOUR MENU BUTTON ON YOUR TV REMOTE.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Samsung Televison & Video
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
Dish Network controller doesn't work if you happen to pause or stop when the screen is black or on a dark picture. You have to turn TV and control box off then back on to regain controller.
falcondan
The remote works fine other than this stated problem? What type receiver and TV do you have? Do this just began occurring? Have you checked the batteries to make sure they are fresh? Is this on TV 1 or TV 2? One thing you may try is readdressing the remote to the receiver.
Remote: All Other Remotes
  1. Go to System Info screen (press Menu button 2 times on remote).
Jun 25, 2011 | DISH Network IR Remote Control
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
How do I progam my remote so it works with dish.. it seems to be stuck on only TV setting, not on SAT!
Hello, this is Matthew Gonzales with DISH Network. If the remote will not change from "TV" mode to "SAT" mode, try changing the batteries first. If changing the batteries makes no difference and you still can not get the remote to change to "SAT" mode, the remote is defective and needs to be replaced. If it does change to "SAT" mode, but is not working you can try putting system info on your screen, (power off the receiver using front panel button, the press "up" arrow on the front of receiver). When systeminfo is on your screen, on the remote press the "SAT"button one time, and then press the "record" button threetimes. Try pressing select to see if it is now working. You canalso try to hard reset your receiver. To perform a hard reset, you unplugthe receiver from its power outlet, wait 15 seconds, then plug it backin. Try reprogramming the remote again with the first part of theseinstructions. If the remote is still not working, it may be faulty. If this has not been resolved please feel free to email me at matthew.gonzales@dishnetwork.com. Hope this helps!
Jan 02, 2011 | DISH Network IR Remote Control
If a tv is on the right channel and the sat button is not working what do you do
leelehudson
Are you getting a picture on your TV? If so, then try pressing the SAT button on the remote and releasing. See if you can now change channels. If not, then the remote may need to be readdressed to the receiver. I have provided the instructions to readdress the remote.
If you are not getting a picture, that's a totally different issue. Please respond to this site with more information.
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Oct 17, 2010 | DISH Network IR Remote Control
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
My dish network remote stop working
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Mar 11, 2010 | DISH Network IR Remote Control
Picture is cut off when watching hd stations on my sanyo 42 inch hdtv
You can't fix this problem using "pix shape" on the TV itself. To fix this common problem, just change the format on your SAT. BOX using your sat. remote; It should have a format button it. Just keep pushing the format button till you get the whole picture to show on screen and you should be set ...
Nov 28, 2009 | Sanyo Televison & Video
Panasonic PT-56WXF95 56" Rear Projection Television Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
