Question about JVC AV-27S33 27" TV
No color The channels are only in b&w, however, the menu has color to it. Any suggestions?
  • 689 Answers
Since menu has color its a great prove that you have no problem with your TVs color. There are few simple causes can be easily eliminated. Check if the colors system chosen correctly (NTSC/PAL/SECAM) depends on source of the picture. Also adjust the Color under Picture settings option. If issue still persists please post for further assistance
Good Luck
Posted on Feb 02, 2008
  • 2,336 Answers
I would suggest to check the color settings on your TV first. If the color settings are normal try to use the audio & video inputs by connecting a DVD or a VCR to them.
If you get the color back with a different device connected to it, It means there is a problem with the tuner or the color circuitry and more likely you will need to get the TV fix by a technician.
  • 4,889 Answers
While looking through the TV menus, Look for "V2 COMPONENT-IN <NO>". chang that to Yes and you will get it in color.
    Novelist:
  • 123 Answers
Does it have a video input? Does it have color when playing a vhs tape or dvd into the video input?
Does the set show the raster lines? Is there any snow showing on the raster?
If the set does not show color with an a/v input either then it is likely the main power supply section feeding the deflection system or the video processing is bad.
RCA sets more than a few years old are not good investments for repairs, unfortunately.
Let me know the answers to the questions above and I can give you a more precise suggestion.
 Good Luck
Was this solution helpful? Show your Appreciation by rating it:
  • 1 more comment
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 02, 2008
    There are so many possibilities. It could be a dead projector tube, leaking cooler fluids, bad power supply connection, broken connector pin and so on. You really need someone who can get inside and find out the cause of failure; it requires one who knows how to observe, take measurements and track down the various possibilities. It is not an easy job on this one and it is not a home remedy solution, sorry to say.
    For the beginner, here are two things you can do - and they don't cost anything.
    ONE: Do a hard reset. Unplug the power cord for 4 full hours, then power it up again.
    TWO: Give it the banging test. Smack the set vigorously with your hand or fist in various places. Doing so will often reactivate a loose connection or cold solder joint. This may bring the red gun back to life - let's give it a 35% chance of doing so.
    If these two procedures don't help you are going to have to bring in the big guns.
    Just a comment: There are over 3,000 parts in a set of this kind not counting the millions of transistors buried inside the several integrated circuits. There are about 12 totally independent sections that function on their own as well as interface with all the other circuits. It is not something easy to do. Even a trained and experienced PHD in Electrical Engineering does not have the foggiest idea about what goes on inside a tv without extensive training in television receiver theory and practice. So, don't feel overcome with it all; there are few who really know this business. IT is truly esoteric in nature.
    Good Luck
    Since menu has color its a great prove that you have no problem with your TVs color.Check if the colors system chosen correctly (NTSC/PAL/SECAM) depends on source of the picture. Also adjust the Color under Picture settings option.
    Good Luck
    it will solve your problem
    Good Luck
I have to resetup all of my tv and cable channels
menu on tv.. click add channels one by one ..add them manually /it should highlight them a different color.. also be sure that your box and tv match as to which channel they come through on.. I just hook my box up to the AV in the back.. and S-Video.. (waiting to get HDMI) but it sounds like your tv isn't "smart" so do it manually, one by one and edit them
I also suggest switching to DirecTV
Sep 03, 2012 | Panasonic Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Set top box, OK, but no color
Suggest you reset the channels on the set top box by going into the menu and selecting auto scan etc.
Sep 24, 2009 | Breville Brushed Stainless Electric...
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Mar 09, 2008 | Televison & Video
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
No color on one channel
Some models of TV's can remember the user settings for each channel programed. Go in to the user menu for the video setup and see if the colour (chroma) is turned down.
Jerry G.
Jul 23, 2007 | Sanyo HT30744 TV
Washed out Color's and No Internal TV Menu's
replace the stk ics. they are located inside the tv with lage heat sinks. i do believe sony runs stk392-510. youll have to look at the ics to know which ones for sure.
May 20, 2007 | Sony KP-61V90 61" Rear Projection...
JVC AV-27S33 27" TV Logo
107 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
