Question about Whirlpool Duet GHW9150P Front Load Washer
Washer not fully draining, even with extra drain/spin cycle...
Ive only had this for 6 months and now if I have a light load (a bath rug, and another time it was a single sweater) it doesnt fully spin the water out, and Im having to wring it out by hand... WHAT A PAIN IN THE BUTT for paying what I did for it... grrrr
  • 12 Answers
Hi easterbunch;
Im sorry to have to tell you but that is one of the inherant faults of the duet line of machines. It is a safety guard that the machine sences as a unevenly distributed load, and prevents the unit from spinning up to full rpm's The next time you need to do a small load throw a bath towel or two in with it and you wonrt have any problems with it spinning up to full speed.
Hope this helps :-)
Posted on Feb 02, 2008
New high efficiency. Washed a bath rug on wrong setting & rug so soaked, cannot even lift it! How do get to run on "Drain & Spin" cycle?
You should just be able to turn on the power and push the "Rinse Drain and spin" button to do an extra Drain and spin OR you should be able to select just the "drain and spin" option with the knob depending on your control panel type.
I hope this helps.
Feb 09, 2016 | Kenmore Washing Machines
Error code f01
all I can say to that is if you arrange the bath rugs in a balanced way so they are equally distributed then the problem should go away eric
Dec 29, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Wont drain
First Try Unplugging the washer for 15 minutes. Sounds like the pump is the issue. Was it a normal load of clothes or a Bath rug or blanket?After you plug the unit in try to select rinse/drain Or drain/spin.
If it starts try to cancel the cycle. The washer should drain the water out for you. Pls update when you can.
Sep 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin,
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
