Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Convergence issues We have changed the convergence and the pico fuses in our Sony 46 inch projection TV and the problem is still going on with the red, green, and blue colors not combining and we also have a curve shaped picture now. Can someone please assist me in this area.
  • 2 more comments
  • betsyadams Mar 19, 2008
    My Sony Wide Screen Projection TV (KP-46WT500) has a problem with the colors. The 3 basic colors overlap--and are blurry. We tried using the FLASH Focus several times --but it didn't help. Need Ideas!
  • Anonymous Aug 14, 2008
    HELP WITH CONVERGENCE PLEASE ! IT WONT WORK AND COLORS ARE ALL OVER THE PLACE
  • nanus0594 Sep 03, 2008
    My Sony 46 inch projection TV displays red, green, and blue colors separately and it also have a curve shaped picture now. Can someone please assist me.
  • Anonymous Sep 10, 2008
    Same problem witho out Sony KP-46WT500, it was working fine one day, turn it on the next and the picture is curved, and red, green, and blue colors outline everything.
Replace the IC'S that's All Guys
Posted on Apr 05, 2008
What do u mean by s
Posted on Feb 28, 2008
  • Sony Master
  • 8,617 Answers
Di you check the resistors right next to the s these usually go out with the ICS
Posted on Feb 02, 2008
6ya staff
SOURCE:
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
My sony hdtv the picture is like a3d effect with red tint flash focus will not work the crosses wont line up any solution or is tv shot?
Replace your Convergence ICs they are Big Black ICs and will have part number on them,
STK392-110. You also need to check the pico fuses in front and back of ICs they will look like resistors Green or Yellow but are fuses 5amps-7amp pico fuses.
Mats Electronics has ICs 1-800-628-1118
Jul 04, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Curved horizontal green lines bout 2 inches apart from bottom to top of screen.kp-46wt500 model
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 14, 2010 | Sony KP-46WT500 46" Rear Projection...
My TV is red and green in 3D--what needs to be
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a Sony convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
93a1209.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 07, 2010 | Sony KP-46WT500 46" Rear Projection...
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Changed the ic's on my sony kp-65ws rear projection tv. (original parts) it fixed some of the bowing problems, and some the green and blue color problems. the red is still off and cant move the convergence...
did you check the two pico fuses on the G board. Usually the picos next to the ICs on the D board will be good, but the ones on the G board will blow when the original ICs failed.
Jul 12, 2009 | Sony KP-65WS500 65" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony Projection TV KP-46WT500 Convergence Problem and Sparking
You may want to get some help with this install...goto www.tvrepairkits.com and ask for some help
Jan 14, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony 46WT500 Display Issue (Convergence?)
converge chip failing after warm up fairly common
to see
Dec 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
