Question about Canon PowerShot S3 IS Digital Camera
Power issues Mine will not power up sometimes after charging even my new batteries. When I tap or hit the battery compartment with my hand and then try it turns on sometimes. I tried cleaning my battery post, still no luck. Help please. Tammie
  • OkiDave Jun 05, 2008
    I am having the same kind of problem on a S3 and a S5... the newer S5 is much worse and shuts down so much my son has given up even using it. The S3 I use at work and has similar problems but will work for a short time if I open and close the battery compartment... I have read that tighting the screws on the battery compartment door might help... will do this when I get home... also read that someone solved a similar problem with WD40 in the camera battery compartment... I hope this works... if it does I will report back.
  • DeeBrand Jun 13, 2008
    I'm having the same issue with my S3. Tried 3 new sets of batteries - all different brands, but it shuts down and tells me to 'Change the Batteries'. How frustrating. My warranty just expired too. Sometimes I wonder... Anyhow - Help! Does anyone know what to do? I need to take product photos right now!
  • 45 Answers
Tried tightening the screws on the door
Posted on May 30, 2008
I have a invicta bolt zeus and it stopped working. When I reset all the hands everything moves except the subdial that reads the seconds. Even when the big second hand moves the subdial doesnt. Also even...
If you suspect the battery try some spare batteries double checking with several known good to brand new one tests to cover your bases for consistency. It is a method of trial and error eliminating any possibility of a battery problem.
Sometimes there are power drain issues where cheep batteries even new can't handle. Trial and error illumination of a power drain issue checking with high power drain capable batteries. Information can sometimes be found in the manual in the specification.
From there you have the insight information it is not the battery in your further investigations describing the problem to a dealer or manufacture.
Other options of investigation include if you have the owners manual to check if there is any special settings to instigate you may need to know about dealers and the manufacture should know as well.
Dec 19, 2014 | Watches
How many hours to charge a new acer 4738?, mine is too long to charge, is it natural if new?
A brand new battery has to be charged for 8 hours.For any battery related issue, a reset or calibration can be done.Just drain all the charge in the battery by using the laptop only on battery power( ie,with the Charger/Adaptor disconnected).After the comp shuts down due to no power,then charge the battery for 8-10 hours and then check if its fully getting charged or not
At times a BIOS update can fix battery related issues.
Oct 22, 2010 | Acer Aspire One PC Notebook
Canon PowerShot A590 IS Digital Camera: Working one day, dead the next. Main batteries not the issue, tried new ones same deal. How can I diagnose? Does anybody repair these things or is it not cost...
I had the same thing happen to my A590. I found the problem with mine was a micro swtch inside the battery compartment. open the battery compartment and you will see the small white tap that is supposed to get pressed when you close the door. I took mine apart and wedged the end of a toothpick under the tab and mine has been working fine ever since. I haven't been able to get an answer as to what the purpose of this switch is but it's been about 6 months and I have seen no adverse effects from my repair.
Good luck,
Bob
Sep 08, 2010 | Canon PowerShot A590 IS Digital Camera
I just purchased a new battery for my acer laptop and although it charges, as soon as the power adapter is removed the laptop shuts off. What do I need to do?
I know this might sound like it too simple a solution, but sometimes even new things do not work. You might have obtained a bad battery that will not charge. Are you sure it is charging? You might also try to remove the battery and check to make sure the connections in the laptop and the battery are clean. Sometimes gunk accumulates in places you would not expect. If there is something other than a nice clean look, try to clean it off. Do not scrape with any metal object - if it will not come off easily, try using a new pencil eraser. Then blow the residue out ofthe battery compartment and try again. If this does not work, it might be a bad battery. The other thing to check is: Look at the connections on the battery and on the computer. Do they look like they match? Sometimes a battery will fit in the battery compartment, but the connections do not match so it will not work.
Aug 22, 2010 | Acer TravelMate 4010 Notebook
My lightly used nikon coolpix s570 has developed a power issue. Meaning that with a fully charged battery, the camera won't turn on. sometimes removing and reinserting the battery will get it to turn on....
If you have a second battery, fully charge it and try it. If you do not have a second battery, it make either be a defective battery or a battery that is not properly charging. Try powering on the camera until you get it powered up, either by reinserting the battery or turning it one. Then purposely use the flash and focus until you totally exhaust the battery. Then charge it for the recommended time. Try the battery in the camera once more. Also look into the battery compartment and make sure there is no corrosion. After these actions, the only other thing I could suggest is trying a new battery or sending it in for repair. Usually it is the battery though.
Mar 22, 2010 | Nikon COOLPIX S570 Digital Camera
When i power the camera up it won't come but the word access pops up and after a minute the message on the back of the camera will read "turn the power off and on again" . what could be the problem .
If the camera doesn't turn on when you move the power switch, remove the batteries from the camera, re-insert them and connect the camera to a camera dock--if you have one. Check the LED lights on the dock and make sure the batteries are charging. Refer to your manual to learn which lights should be on when the batteries are charging. If they are not, try powering the camera back on after inserting new batteries.
Also try cleaning the battery contacts in the battery compartment using a clean,dry lint-free cloth. Sometimes, little particles can cause short-circuits in the battery compartment. If the camera still does not turn on after you clean the contacts, your camera may have had a power failure. Contact the manufacturer.hope this helps you
please do rate me on this issue
Nov 21, 2009 | Cameras
Change the batteries message even with new NIMH RShack batteries
The solution is to change the small 'date/time' battery. You can have the regular batteries as charged as you like, it won't make any difference. The tiny date/time battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open).
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
When i hit power it does not turn on
Two possible solutions.
1. Your battery is dead and is not taking a charge. Replace the battery.
2. Blow some compressed air into the battery chamber to be sure there's no debri or dust messing with your connection. Be careful not to blow compressed air on the lens or in the camera body other than the battery compartment area
Apr 20, 2009 | Cameras
Power Problem
This could ba caused by several things. First, a bad power supply. Second, a bad battery, try starting it without the battery. Third, a bad memory chip. And fourth, the power management chip on the motherboard. If it's not the battery, power supply, or memory chip, then it's the pm chip and the motherboard will have to be replaced.
Jun 25, 2008 | Dell Latitude D600 Notebook
Samsung digimax 201 not turning on not even with fresh batteries
It could be anything... Did you over charged the batteries (if rechargeable)?
can you see if theres any broken tin inside the battery compartment?
does the power button taps normally when depressed?
is the camera still under warranty?
Dec 04, 2007 | Samsung Digimax 201 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
69 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
