Question about Toshiba P25-S670 Notebook
Laptop Power Issues
I have had this Toshiba laptop since late 2004 and never had any problems (besides occasionally overheating) until about a year ago. The laptop has remained dormant since then and I have put this problem off for awhile but it's time to hopefully get this issue resolved. I will try to be as clear and concise as possible.
The original charger was damaged so I bought a new, generic version about a year ago. It was all downhill after that. The computer would turn on for a few minutes and then shut off with no warning (I have seen this problem in another post) almost like it was overheating. All three lights on the front of the laptop would light up and then shut off except for the green ac adapter light so it was recognizing that it was still plugged in to the wall. The orange battery light would blink sporadically and then shut off as if the connection was spotty and not getting through. After only a month or two the charger began to act up and the sound of crackling live electricity could be heard coming from it. I figured the problem had to be the ac adapter.
I just bought a new charger about 2 days ago and gave it a try tonight. The computer started up, ran for about 10-15 minutes without issue although it was very slow. All of a sudden it shut off again. The battery had been charging during this time and got up to a 9% charge. Upon starting the laptop up again, the charge dropped to 5% and then 0%. The orange battery light began methodically staying lit as orange and then blink 2-3 times and go dark. This continued for about 5-10 minutes. At this point I thought it may be a dead battery. However, now the laptop is still plugged in but none of the lights are lit up and the power button will not respond.
The charger seems to work fine so I ruled that out. I then figured it was a dead battery but the laptop should still power on even if the battery is out and it is plugged in to the wall, correct? Short of ordering a new battery and trying that I am not sure what else to do. Could it be an internal power connection problem that can't be solved with a new charger or battery?
Any help would be greatly appreciated. Thanks.
  • 4 more comments
  • styce Feb 05, 2008
    Thanks for the comments.
    An update on what's happening. I have left the laptop plugged into the wall without the battery (the tv tuner in its place). The ac power light has been lit for about a day or two. I just tried to put the battery in and the laptop turned on and all three lights lit up. The battery light glowed orange for about 5 minutes as I started the laptop up in safe mode. It never held a charge. I performed a few tasks until the laptop again shut off without warning (~7-8 minutes). The ac light remains lit however.
    You may be on to something with the battery gobbling up power from the charger. I am going to order a new battery (which I probably should do anyway considering the original is so old) and see how the laptop responds. This seems like the most logical next step before taking it in to the shop.
    Also, the charger I have is 19V and 6.3 Amps so that matches up. I am looking on-line right now and am trying to choose between a battery which is DC 14.8V & 6450 mAH or the DC 14.8V & 6600 mAH. The former possesses the specs on my ol battery but in my internet travels I have seen the latter as being compatable with my laptop as well (it is cheaper too). Is there a significant difference in terms of the mAH levels and the effect on the laptop?
    Thanks again for you help.
  • styce Feb 13, 2008
    Update: I just received my new battery and upon plugging in the laptop with the new battery in place, both the green ac power connection light and the orange battery charging light came on. I let it sit for about 20 minutes and then started it up. The computer ran on its own for about 5 minutes before the battery light turned off and then the laptop itself shut off about 5 minutes after that. Now, the laptop is showing no lights on (even when the ac cord is plugged in) and the power button won't respond. I unplugged the ac cord and plugged it back in and the green light came on. The power button then responded but the laptop quickly shutdown again. Very odd. I feel like some internal connection must be off for this type of thing to keep happening. Any more ideas short of shipping this thing to Toshiba?
    Thanks.
    I read your comment and decided to be more patient so I left the laptop plugged in all night. The battery light somehow remained lit up as orange all night signaling that it was in fact charging. I am not sure why it decided to stay light all of a sudden after beginning the night very unreliably. When I awoke this morning, the battery light had turned green meaning a full charge (it had been charging for about 10 hours). This was exciting as I had not seen this happen in almost a year. The laptop turned on fine and ran well with all the lights on for about 10 minutes. Then the battery light went out. The battery charge read 100% and even when I unplugged the ac cord, the laptop continued to run fine - even though the battery light was still dark it had accepted a charge and was working. The charge of the battery decreased at a normal pace and was about 50% when I left for work this morning. I tried plugging the ac cord back in before I left and the battery and the battery light would still not accept a charge/light up. Why would the battery initially accept a full charge and then not recognize the ac cord? Any ideas?
    I am letting the power drain completely from the battery and then I will charge it up again when I return home. Thanks for responding so quickly last time.
  • styce Feb 19, 2008
    Sorry I posted this as a solution #2 - Hey there again, after a few days of testing out the battery I am still unsure of the problem. If the laptop is off and the ac power cord is then plugged in, the battery will charge to 100%. Once the laptop is turned on however, the battery light will switch off and the battery will drain down to nothing and finally the laptop shuts off. The whole time, the power icon says the laptop is running on AC power yet the battery still drains. The battery will not charge again until the ac power cord is unplugged and plugged back in while it is off. This is the most consistent the machine has been in awhile but it is still odd that it's not recognizing that it is plugged in when powered on. Any more ideas? Thanks again for your help.
  • styce May 29, 2008
    Hey everyone, I never did end up solving the problem. I bought a brand new ac adapter and a new battery but it still has the same problem. It charges for a bit (when it's off) and then once the power is turned on, the orange battery light will turn off causing the machine to shut down immediately (or shortly thereafter). Only when the cord is unplugged and then reinserted will the battery even think about charging but the response is spotty. I try jiggling the adapter once it's in but the results are mixed. The issue may in fact be a faulty dc jack but short of taking it to a repair shop or sending it to Toshiba I can't confirm this.
    All I can say is that the laptop often shut down on its own within a year or two of purchasing it and I thought this may be because of overheating or too much dust being taking in by the numerous fans. I ended up elevating the laptop off my desk and this solved that problem. The current problem started after tripping over the wire and denting the dc jack a little bit. I always thought a faulty jack may be the problem but never wanted to send it in to Toshiba for repairs.
    I haven't tried to use it in about a month though. I will check it right now and post any changes in the situation.
  • Matt33333 Jul 08, 2008
    I've got the exact same problem with my Toshiba Satellite... have gone through 2 adapters with the second one making a crackling electric noise... now considering buying a new battery. I never did see a solution posted on here. Any ideas?
My probleams is when starting pc and at that moment laptop noise create so whats i can do piz given reply
Posted on Nov 03, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
The laptop shut down unexpected the first turn on, but working good the last open? It cause as the mainboard heat too hot and the power supply fan problem. You may clean the ash of power supply fan and change a new fan for your laptop mainboard. Or you can dip some lubricating oil into the fan.
After doing this if the problem cant be solved, please change a laptop battery, as the precarious power can damage your laptop. See more laptop battery replacement in http://www.laptops-battery.co.uk
That's all i know, hope it can help you. Good luck
Posted on Dec 18, 2008
Bad motherboard transfering
Posted on Jun 16, 2008
Did you ever figure it out? I have the same problem on my laptop
Posted on May 28, 2008
  • 3 Answers
Have you checked the power options in the control panel, if set incorrectly they could cause problems. Also are you having any problems with the ac adapter plugging into the dc jack and being loose in anyway, if so you might need a new dc jack which is a costly repair but is still better than buying a new laptop. If you are good with a soldering iorn and have a steady hand and follow directions well you can do it yourself for around 8-15 dollars. Otherwise it will cost you 200- 300 dollars to fix. Email me @ texantothebones@yahoo.com if u need more explaining.
Hi! I have the same problem with a Dell Inspiron 1100. Turn it on and after a while, it shuts itself off. Last like 10 or so minutes. Tried to back up files off the hard disk and now after you power it on, it shuts itself off after 5 seconds! I removed the battery and ran it on AC power - same thing - power it on, it turns itself off after 5 seconds.
Any clues?
Thanks for help!
Mike
Posted on Mar 06, 2008
Posted on Feb 19, 2008
    Brigadier General:
  • 6,966 Answers
Most laptop batteries would die out after a year or two. None the less, the laptop should work with or without the batteries.
In some instances, the batteries have deteriorated to the point that it will gobble up the power from the charger denying sufficient juice for the laptop's use. The temporary workaround is to use the laptop without the batteries. if removing the battery and the unit powers up/works, then you have verified that indeed it is the battery causing you problems.
If even without the battery the unit will not operated, you can suspect the charger not 100% compatible with your laptop. If it is an original charger, then you can conclude that something is wrong inside the Toshiba.
I understand that the original charger intended for a Toshiba P25-S670 is 19VoltsDC. 6.3Amperes (120Watts).
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 02, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Feb 05, 2008
    Hi again Styce,
    Appreciate the update and you're more than welcome.
    The only difference between the DC 14.8V & 6450 mAH and the DC 14.8V & 6600 mAH is that the latter technically should last longer. If this would be cheaper, it would be to your advantage to get the 6600mAH.
    There is no significant effect on the laptop's performance other than increase in length of time of usage.
    Cheers.
  • Louie  Role
    If I may add,
    New batteries would be better off having a continuous initial charge of at least 16 hours.
  • Louie  Role
    Louie Role Feb 13, 2008
    and hello again Styce,
    Most new batteries need to be charged a loooong time just to get them to speed. Thereafter you would be back to normal power usage and depletion.
  • Louie  Role
    Louie Role Feb 14, 2008
    There has been several issues with laptop battery being manufactured by another firm for the laptop company. What is to be realized by us users is that the life/usefulness of the battery starts to countdown the moment it leaves the factory even before it is received by the laptop company or the reseller, dealer, wholeseller, importer.
    As in your case, perhaps what would be needed is to exercise the battery and allow it to settle to a normal pattern of charge/discharge-use.
    Some batteries are also intelligent in a way. They automatically disconnect any charging when they reach a certain temperature on the assumption that at certain temp, then it has fully charge.
    In any case, pls add more to your patience and give the battery a chance to settle in into its new home.
Toshiba A105 problems
Step 1:
It can be very frustrating when you encounter a problem with your Toshiba Satellite laptop computer. Unfortunately, these specific Toshiba laptop models have a tendency to run into certain problems because of their design. On the plus side, computer technicians have pinpointed several of these issues, and they have troubleshooting information readily available to assist Toshiba Satellite owners. These are some common issues and solutions.
Overheating If the laptop shuts down randomly whenever you attempt to run different programs then it is usually happening due to an overheated laptop. This can occur because your heat sink is filled with dust, which affects the operation of the cooling fan. The heat leaving the processor gets trapped in your laptop resulting in overheating and shuts down. Purchase compressed air in a can and blow it either into the air intakes located on the bottom of the laptop or you can remove the keyboard to get to the cooling fan and blow the dust off. If this doesn't remedy the problem, you may need to replace your cooling fan; you should hear it start working when you boot up your laptop. b> Defective Memory This problem is typically recognized upon start-up. If you see strange characters or lines of dots on your screen, this suggests defective on-board memory. To test for this problem you need to remove external RAM modules and download the Memtest 86+ utility and burn it to a disc (see Link Below). http://www.memtest86.com/ You can then run the utility from the disc after restarting your computer. Unfortunately, if this is the problem you will have to replace the motherboard. b> Power Jack Problem Power jacks on these laptops have a known history of losing contact between the positive pin and the motherboard. You can diagnose this problem if you notice your laptop using battery power when the power adapter is still plugged in. To fix this problem you have to disassemble the laptop and take out the motherboard. You then have to solder the power jack (this should only be performed by those with laptop repair experience.) b> Charging the Battery If your laptop will not turn on when starting on battery power or the battery charge LED light doesn't light up when you plug it into the power outlet, the battery isn't properly charging. For Toshiba Satellites that only operate when they are plugged in, you need to download the latest BIOS for your Satellite model from the Toshiba website. Toshiba recommends you should use version 1.30 or newer (see Link Below).
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Feb 14, 2013 | Toshiba Satellite A105 Notebook
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
I purchased a Toshiba Satellite C655D-S5084 in late December, and after, NOT EVEN, 7 months later, I began having issues. The laptop ran FINE, and was fantastic, however... it was having issues charging....
Hi
I have seen this problem many times, and in every case, it has been a wire broken between the output of the charger and the plug that goes into the laptop. If your laptop has a "power connected" led, then that should give you the answer, assuming you don't have a voltmeter to test the output.
Mar 17, 2017 | Toshiba Satellite C655D-S5084 Laptop
My 4 year old Toshiba INtel Pentium laptop consistently shuts down randomly after about 10-20 minutes of activity at first only when plugged into specific power outlets but the number of "bad outlets" has...
Hi
Thank you for your query
From what you are describing it sounds like a intermittent motherboard issue
Please try the following
1) Switch on your Laptop
2) Press F12 or del key or esc to enter bios mode
3) Once in bios mode leave there and see if it shuts down
4) If it does shutdown thne you are having a overheating issue and i belive it will be the heat sink that has gone faulty, you will need to book into a reputable PC shop for repair
5) If it doesnt shut down in this mode then you have a softwqare issue and will need to carry out a full reformat of the laptop
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank you again
Feb 14, 2010 | Toshiba Satellite 1805-S274 Notebook
Laptop screen inverter issue (Toshiba Satellite A205-S4587)
Inveter issues are a common fault on laptops both new and old. In many cases it is up to the individual to decide if the laptop is still going to fulfill thier needs for the next few years if it is repaired or sold to provide some funds towards a new laptop.
I have not seen any special cooling products for inverters. I have seen laptops used as desktops with the screens left running for weeks on end which is not the primary purpose of a laptop. conditions such as those could lead to heat build up and the issues you have seen.
If you are confident enough to do the repair yourself then you can keep your repair costs to a minimum and replace the inverter.
Aug 08, 2009 | Computers & Internet
Loud Fan and Slight Overheating
most likely sounds like your hard drive. Mine did the same thing starting that loud whirring noise and overheating a lot. i took it into geek squad at best buy and it cost 199.99 for the diagnosis of the problem and the repair ( if you want just a diagnosis its 69.99) and then had to buy a hard drive ( i went for the 320 GB for 109.99) and they installed it for free same day in and out. took the whole process about 5 hours on a friday afternoon.
Apr 19, 2009 | Toshiba Satellite A135-S4527 Notebook
It doesn't work on battery
check the power option in control panel, also remove the battery then insert it again
Oct 17, 2008 | Toshiba Satellite A75-S211 Notebook
Toshiba Satellite M45-S359 Laptop Power Jack Issues
well the adapter for toshiba laptop is weak, and the most common method is to use a multimeter with the electroprobes connect to the anode and cathode.if it is normal, the pointer will fix in a short time.
May 31, 2008 | Toshiba Satellite M45-S359 Notebook
Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
May 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
!!! TOSHIBA SHUT DOWN !!!!!!!
If ventilating helps, check that the vents on the bottom and where the fan blows out warn air are'nt blocked, try gently hoovering around area witha nozzle.
Oct 21, 2006 | Toshiba Satellite A60 Notebook
Toshiba P25-S670 Notebook Logo
696 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
