HP Pavillion ze1000 laptop will not power up
I have a HP Pavillion ze1000 laptop that will not power up, I plug it into an ac outlet, the led in front is red for a few minutes then turns green. Can anyone help?
  • Abelardo Feb 03, 2008
    I've got pretty good t-shooting and repair/soldering skills ( i work with automotive electrical and electronic systems). But with consumer electronics, i don't have a lot of experience. if you could point me in a direction, points/voltages to check, i've got the equipment to do so, i'd really appreciate it.
    Sergeant:
    Habit-Forming:
  • 194 Answers
That could be one of many problems. bad power supply, loose power connector, zapped motherboard. that model as i recall, had those problems,
Posted on Feb 02, 2008
  • kj henriksen
    kj henriksen Feb 03, 2008
    try a 12 volt cigarette lighter plug in a car with the proper cable.
    i've had luck starting some laptops that way.
    then, one knows the power brick is bad.
Hp 764c will not power up
First check if your adapter is good. Most adapter has an LED indicator, then check your AC outlet. Be sure to firmly insert mthe plug of the adapter onto your laptop's power socket, most laptop do have an LED indicator. IF you haven't seen any lights, that means the adapter or the plug or the socket is bad.
Good luck
Tedmac
Oct 13, 2013 | Computers & Internet
Hp pavillion lighitng bolt led on front keeps flashing and will not power on
I see that you said that you "powering on the AC adapter only".
Does that mean you tried booting with the battery removed?
If not, completely remove the battery and try to boot.
If that fails too, it will be a switch or board issue
Mar 12, 2013 | Computers & Internet
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
Pavillion dv2025nr Blank Screen, but all LEDs on.
VGA card problem..that's what tech told me & changed it 3 times...but still laptop goes off.(exactly like u described)...they finally said need new motherboard??? so VGA will not do this again!!!! I don't know, If I change motherboard...will this happen again...is it worth it??? My pavillion dv 2000 is only 1.5 years old..was expensive??/
Oct 01, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavillion dv6700 does not power up
cpu is not getting the power coz the smps is not supplyin power to it so change ur smps or chk its wires
Aug 22, 2009 | HP ProCurve Switch 2650
HP DV2036ea i have a blank screen on the computer
Hello there
Description.
When pressing the notebook power button nothing is displayed on the screen or display. The cause of this problem may be a failed AC adapter, the memory modules (RAM) need to be reseated or a failed notebook system board component which will require an HP certified repair.
Below steps will assist in identifying the cause of the problem and suggest the best solution. Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. Check the power indicator light or power socket LED On newer models of notebook PCs, there is an LED or indicator light around the power socket on the notebook. Check to see if this light is on or off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
  • If the light does not turn on then the problem is most likely related to the AC adapter or the electrical source in your home or office. Go to the Light does not turn on section on this page.
  • If the light does turn on but the notebook does not start or the there is a blank screen then continue to the Light does turn on but the notebook does not start section on this page
The light does not turn on when the AC adapter is connected If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
  1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
    NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
  2. Check all of the following connections:
    • The connection from the power cord to the wall outlet.
    • The connection into the power adapter from the power cord.
    • The connection from the AC adapter to the notebook power socket.
  3. Press the power button again to test the notebook PC.
If the power indicator light still does not turn on, then the AC Adapter needs to be replaced. Contact HP Service and Support for further assistance. Power socket LED or power indicator light is on but the notebook does not start If notebook power indicator light (LED) is on, the AC adapter is working correctly. The problem is a result of a hardware failure in the notebook itself. In some cases, reseating the memory module (RAM) may solve the problem.
Feb 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
299 people viewed this question
Alun Cox
David Payne
David Payne
