Question about Onkyo TX-SR605 Receiver
Problem with component input and 720p HDMI output
I bought this receiver from Amazon, found the particular problem I describe, figured it was a faulty receiver and returned it to Amazon to get a replacement - the replacement has the same issue, so I'm starting to think it's a "feature".
I have my Cable box connected via Component out to the receiver. Then output via HDMI to my TV (which supports up to 720p, not 1080p). I often get picture distortion while watching cable. Picture flicker on all or part of the screen, especially when there is a cut between scenes on the program I'm watching. On occasion, the picture has even disappeared for a couple of seconds, replaced with green screen and then returned. I've also had weird incorrect pallettes when switching from an SD channel to an HD channel. Restarting the receiver fixes this. The same issue has occurred in BOTH receivers I've tried which makes me think maybe there's an issue with component to HDMI 720p conversion. Any ideas?
  • churwitz Feb 02, 2008
    Nope, no HDMI out from the cable box. I'd like to keep using the hdmi out from the receiver. That's why I bought it.
  • GSAG Feb 08, 2008
    I have a similar problem, and am on my second onkyo SR605 receiver as well. I have hdmi cable from my direct tv cable box to the reciever and hdmi cable from the receiver to a sony 32 inch 720p television. What happins is the tv will get a little snowy then horizontal lines appear then the picture turns a pink purple color then maybe greenish then no picture for about 5 to 10 seconds then the picture will come back to normal. This could happen after an hour of watching a great picture. When bypassing the SR605 no problems appear. I have even swapped out hdmi cables. Any help is appreciated.
    GS
    Scholar:
  • 84 Answers
Does your cable box have an hdmi output? if it does try an hdmi cable instead of componant cables[ i know the hdmi cables aren't cheap] if not, if the reciever has componant outputs, use them instead.
hope this helps
wg
Posted on Feb 02, 2008
  • wilson garcia Feb 02, 2008
    try the componant cables instead of the hdmi just to see if that's causing the problem [conflict with componant to hdmi]
    wg
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Hi t here, I have a Yamaha Rx-V363 Home Theatre System. As all my HDMI ''in'' ports are used I would like to connect my PS3 to it via an HDMI To RCA converter cable. I bought the cable but cannot figure...
you should not do that, your quality of the ps3 when then be horrible!, instead just go on amazon.com and look for ps3 component cables, and get those, you may not be able to go to 1020p but you will atleast get to go to 720p, but that is way better than the RCA' 420i, trust me! For further information, if you have an HDMI cable, then use a Addapter to convert it into something else other than that, it will downgrade the quality dramtically, stick to component and hdmi cables for now, RCA is poop!!
Jul 09, 2009 | Yamaha RX-V363 Receiver
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Its not broken or nothin i was wondering how to put the input for cabel from cable/sat to colorstream hD1
Cable boxes or satellite receivers typically only come with audio/video output, RF output, and component output. You need an upgraded one which has the Hdmi output jack. The upgraded box will cost you a service fee around $5-10 a month, so if you don't want to pay to receive the 1080p service you can receive 720p by using the component video output leads from your cable box.
The quality is almost as good. The only difference will be that you won't be able to receive the hi-def channels that the cable company offers.
Apr 29, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Onkyo TX-SR605 Receiver Logo
657 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
