Question about Toshiba Satellite A100-S8111TD Notebook
This is an hp computer
When i log on to my homepage it blinks an then that error message comes up an then it closes it out an says to restart the program. but when i do it dose the same thing please help me i the uninstalled IE an then reinstalled it, ive tried the deleting the temp files nothing is helpin is there anything else that i can do to get to the page an for it to stay up
    Novelist:
  • 113 Answers
Try using the Control Panel - Internet Options to set your home page to blank. That should allow IE to start up properly. You can then try surfing to different sites to see if it works correctly.
If the problem persists, we'll need to try something else, though.
Posted on Feb 02, 2008
6ya staff
SOURCE:
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    What does it mean when a letter e blinks and the printer does not print on a hp psc 1410?
    E = Error - IE: paper jam, etc... reset & restart and check errors message on computer
    Mar 17, 2011 | HP PSC 1350 All-In-One Thermal Printer
    Pavilion 510c PC Desktop: it wont boot ...it will come on but it will then g...
    Hi if u get an error message after u log on to the desk top then u need to go to start ?run ?type msconfig? (do a clean boot )this is how u do? go to the startup tab click on disable all ? click on apply ?go the the services tab then check the box that says hide all microsoft services?then click on disable all ?u might get a message that access is denied dont worry click on ok and then close the page.It will prompt u to restart the computer ,restart it and then check u should not get the error message .Then u need to go to the same screen by typing in msconfig and then u need to find the program that is causing the error to come up .First enable all the startup items restart the computer and then check for the error if it does not then uncheck alleast 4 programs restart the computer and then check if u get the error or not so this way you will have to find that particular program that is causing the error to pop up and once u have found it just uncheck that particular program .
    all the best
    May 05, 2010 | HP Pavilion 510c PC Desktop
    Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Error! An unexpected internal error has occured. Click OK to close the program, and then try one of the following; - Restart the program - Restart the PC and then try again -...
    Please clarify what program you are using when this error message accures. It seems like it's possably just a software problem, so what I would recommend is to check your event log to see what errors it is logging. The answer to your problem may reside in there.
    Aug 15, 2009 | HP Officejet Pro L7680 All-In-One Printer
    Error messages appear when scanning from glass to macbook.
    • Unplug the Scanner cable from the computer.
    • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
    • restart the computer
    • try to download drivers from the website
    • after installing drivers and software it will ask you to connect the Scanner.
    • then you can connect the Scanner and and try to Scan.
    Hope this help. Please Rate My Response! Thanks!
    PREM
    Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Server error
    Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
    Mar 02, 2009 | HP ProLiant ML150 G3 Server
    Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
    Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
    • Turn the computer on or Restart the computer
    • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
    • Ensure that the Safe mode option is selected (the top option)
    • Press Enter. The computer then begins to start in Safe mode.
    • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
    Oct 31, 2008 | HP Computers & Internet
    I have a BRAND NEW HP Pavilion Notebook which I just switched on for the FIRST time. It has come up with an error message, ie: "The computer restarted unexpectedly or encountered an unexpected error....
    Your windows installation CD might have become corrupt. Use a fresh CD and enter into BIOS settings to set Default Settings before installation.
    Try & reply.
    Sep 11, 2008 | HP Computers & Internet
    Toshiba Satellite A100-S8111TD Notebook Logo
    41 people viewed this question
    Top Toshiba Computers & Internet Experts
    Ekse
    Alun Cox
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
