Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Ice forming in Freezer Basin
The first time I noticed the problem was when our water pressure was reduced to a drizzle by the utilities co. I found that the ice maker basin had frozen and backed up. Then the water supply was overflowing and dripping down the inside of the freezer and the ice bin. So I defrosted the entire freezer thawled the ice maker. I am no longer experiencing any water from the to p of the freezer but I am still getting ice forming in the basin. So I again removed averything from the freezer removed the back aluminum cover and notice a little condensation on the back cover. I thought that maybe the temp was not high enough and set it too cooler and replaced everything back in the fridge. Not fixed? I am still getting ice formations. I have read other similar problems but I am confused. I can see a drain that has a rubber plug. Is this the same drain that is the evaporation line or is there another one I should be looking for? I do not see a drain pan underneath the fridge so I am concerned that if all of this water drains daily it will eventually end up on the hardwood floors. Please help?
    Scholar:
  • 27 Answers
Hi. That is the only drain for the evaporator water during the defrost cycle. Take the back aluminum cover off again and pour hot water into the drain. If it won't drain, take a hose and put it over the drain and blow into it. That will remove the sludge in the trap and it will drain good now. I've seen alot of nice hardwood floors damaged with this problem. Good luck, Mack
Posted on Feb 02, 2008
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Water forms in the bottom of the freezer section. The water supply has been turned off
The issue you have there is not with ice machine water, but with condensation flowing onto the floor because the drain pipe channel is blocked. You need to defrost for 5 hours and then move behind to the compressor. Locate a small pipe above the compressor which drains into a basin. Blow hard into this pipe and you will feel the pressure release. The blockage will then be clear. Ready to go.(Dont put compressed air into the opening as this can rupture the tube if it is iced up.)
Sep 07, 2010 | Maytag MSD2454G Side by Side Refrigerator
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Ice forming in the bottom of the freezer, not from spilled water.
you probably have a stopped up draing behind freezer wall panel
Sep 19, 2009 | Maytag Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice forming on bottom of freezer
Switch off the power
First keep all the items out
Open the door and remove all the fixers
let the whole body will be get dry
check the freezer is there any gap between the door
Let me know if your problem is solved and rate me as FIXYA!
Mar 07, 2008 | Kenmore 73503 Stainless Steel Bottom...
GE side by side W/ ice and water dispense
If you have ice forming on the back of the freezer wall it is an indication of a problem with the defrost cycle.Could be defrost timer,hear or termination swith.
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
