Question about Garmin StreetPilot C330 GPS Receiver
Putting maps on sd memory card
I managed to update my c330 with the 2008 map update but could only load lower north America, United States, Hawaii, an etc. I would like to put Canadian map on an SD memory card. Is this possible, and what is the best way to accomplish this.
  • 2 more comments
  • arbutus_bill Feb 15, 2008
    Yes I did know that you can order the sd chip from Garmin. My problem with that is I just spent $75 dollars for the ver 8 update. I believe that it is wrong for Garmin to charge me another $80 for the Canadian maps. A blank sd card can be purchased for as little as $10. The procedure to download the maps is what I need. It is not as simple as downloading to the sd card.
  • Garry D Mar 04, 2008
    Exactly the same problem, exactly the same sentiments about Garmin.
  • Anonymous Mar 09, 2008
    I tried Gary_D's solution.
    I did not have a 512MB card, so I used a 1GB card.
    It did not work.
    The c330 may not recognize a 1GB card
  • Anonymous Feb 12, 2009
    Map update 2009 does not have the gmappromU.img file
    Any ideas how to do this for Map update 2009
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Posted on Mar 04, 2008
I have a kodak easyshare c330 and was wondering what it can hold up to in terms of memory, i had a 256mb sd card that worked, but when i bought a 2 x 2gb sd cards from two different stores they didn't work and both came up with the same error.
Posted on May 14, 2008
  • 504 Answers
The restriction on the C330 is due to memory limitation. It cannot hold all the 2008 updates. Canadian maps are available on an SD card from Garmin:
microSD/SD data card, City Navigator Canada NT Part Number: 010-10966-00
Suggested Retail Price: $ 79.99 USD Normally ships in 1 - 3 business days
As far as doing it yourself, I believe these can usually be downloaded to a blank SD card, but I also believe the cost is the same from Garmin.
Posted on Feb 14, 2008
SOURCE:
Can a New York card be used in Florida ?
Depends on the make and model. Garmon splits the US up. The chop of California for some reason.
City Navigator North America NT Lower 49 States Garmin
This one does all of North America, so check your maker.
https://buy.garmin.com/en-US/US/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt/prod1456.html
Dec 02, 2015 | GPS
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
Why when I try to enter an Address with State = California, my Garmin Nuvi 660 only shows "Cayman Brac" and "Connecticut"? I'm on software version 4.90 and I have "CN North America NT 2015.40 ([1] Lower...
CN North America NT 2015.40 ([1] Lower 49 States NE)
NE = NORTH EAST... California is not in the North East of the United states. This device only has a small internal memory so you need to use a 4 GB memory card and load maps to that card with MapInstall:
How do install mapping to my device with MapInstall
Mar 24, 2015 | Garmin Nuvi 660 GPS Receiver
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
Need a North America SD Card map for my European Garmin nüvi 255w. Where can I buy one on line
You can buy direct from Garmin via this link. You can opt for instant download, purchase of SD memory cards or DVD ROM medium. You may also be able to buy maps at some of the outdoor stores and electronics specialty shops.
If you plan on using this GPS in North America from this point on, you might want to look into purchasing a "Lifetime Maps" subscription for about $119 instead of the one-time map purchase for $79. The subscription allows you do download updated maps up to 4 times per year, for life of the GPS. Contact Garmin Support directly for more info about this option.
Nov 22, 2010 | Garmin nuvi 255W GPS Receiver
Is there any update for the sanyo nvm 4370
http://us.sanyo.com/Navigation-Systems/Easy-Street-NVM-4370-Portable-Navigation
Pre-Installed Maps: Set up of the Easy Street Navigation System is simple because there's no software to download. Maps are pre-loaded and ready to go. Map data covers the US, including Alaska and Hawaii, Canada and Puerto Rico.
SANYO NVM-4370 Map Update DVD North America 2009-2010: Get accurate directions to wherever you travel including new roads, new sub-divisions, and current addresses. New and expanded coverage in over 159 cities, counties and metropolitan areas across the continental United States and Canada including Alaska, Hawaii, Puerto Rico and the U.S. Virgin Islands. You can confidently drive through unfamiliar or recently changed areas. This latest edition features over 6.18 million miles of navigable roads and an updated list of over 7.57 million Points of Interest to help you find the way to where you want to go quickly and efficiently.
Sep 17, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Nuvi 205w won't read upgraded map
You HAVE to go through software support as this is an issue with the map. They told me it is because the map KEY is wrong, it is only for the united states, but the map is ALL of north america. The wait time is incredibly long, I have been waiting for over an hour, such bad service
Apr 17, 2009 | Garmin nuvi 205W GPS Receiver
Not enough space for maps?
The garmin does not have any space on it for maps,any additional maps are stored on a memory
card. I don't see where garmin says the size limit of the card but in most cases unless it says
SDHC memory card,then the max is a 2g sd card, I think the models 500 and over can use over a 2g card.,
Mar 27, 2009 | Garmin nuvi 200W GPS Receiver
How do I unlock the Canada maps?
I had same problem, purchase Sd card, because internal memory too low for all Canada and Usa. search thepiratesbay.org for unlocker program. It works like a charm. Ps i dont know the legality of using unlocker so you may want to consult Garmin.
Jul 26, 2008 | Garmin nuvi 200W GPS
Garmin StreetPilot C330 GPS Receiver Logo
32,943 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
