Question about Sharp 32SF560 32" TV
The screen tilts to the left
On my sharp TV the screen tilts to the left. It's very noticeable when watching a wide screen movie, but there isn't and hold adjustment. Can I still fix it myself?
  • 579 Answers
The coils on the yoke that control the CRT must have shifted in order for the display to be tilted. A rare thing. You will need to take it to a competant tech to realign the coils as there are magnets and shims that all work together to get the picture to come out right and it is tricky to do.
Hope Ya Fix It!
Posted on Feb 02, 2008
6ya staff
SOURCE:
There are 6" wide gray bars on each side ot the TV
The grey bars signal that the source image is originally in 4:3 format - if you are using a box of some kind get in its menu and change the format from there to 16:9. The black bars appear when a 16:9 image is sent to a 4:3 format in Letterbox mode - leave it like that or the Pan and Scan mode will chop the sides.
Jul 20, 2011 | Panasonic Viera TH-42PX80U Plasma TV
The sides of the picture are cut off. It's like trying to watch a wide-screen movie on a regular tv.
Check that the Aspect Ratio settings aren't left in Zoom. Maybe set to Full or 4:3, depending on the picture format.
Aug 17, 2009 | Zenith A32B41W 32" TV
My dvd player doesn't fill the screen on my Sharp
There are settings on most DVD players as well as TV's that allow you to adjust the type of display you want. Make sure both the DVD and TV are set to the same display type (usually either 16:9 for your type of TV). If that still does not fill the screen you will have to use the Zoom function on either your DVD or TV. This will cut off part of your movie, but should allow you to fill the screen. Most DVD movies will also allow you to choose widescreen or normal viewing from their menu. Again, you will lose a small part of either side of the movie, but at least you will fill your screen.
Jul 07, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Screen problem
it is clearly a case of "you got ripped off" just like me
Feb 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
New Samsung 1080p TV not displaying Full 1080 from PS3 Blu Ray movies
Hi hsaucier,
Although you have a wide-screen television, it is possible the video you are viewing was recorded in an even wider format. The bars should be smaller than if you were viewing the same DVD on a TV with a 4:3 aspect ratio, but will likely not disappear unless you view the DVD at a zoom setting. Many movies are shown in theaters at a wider ratio than 16:9, and the Blu-Ray disc has probably retained the entire picture rather than cropping it to fit your screen.
I recommend trying different viewing options that zoom in slightly. Be aware that this may cut off part of the picture from the left and right sides, but depending on your personal preference, you may not notice anything missing.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 15, 2008 | Televison & Video
Vertical Tilt on Screen & Occational Blue Spot
firstly check the 1000micro farad near the ic vertical,u have to change it.
secondly for the blue green change the positor,if you dont know where it is!!!! it the near the degassing plug
Apr 20, 2008 | Sanyo DS24425 24" TV
Mitsubishi
you need to do self test first look in threads and also ctechnicians.com to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
Sharp 32SF560 32" TV Logo
95 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
