Question about NEC VT575 Multimedia Projector
Svideo and component video inputs
Neither the s video or component video inputs are working on my NEC VT575 projector. Is there a menu setting I need to change? What else could be causing it? Both computer inputs are working
    Brigadier General:
  • 6,966 Answers
Normally in most laptops, you need to press a combination of keys to activate the external video outputs (such as your S-Video and/or the analog/vga/composite. It would be Fn + F? depending on the brand/model.
In desktop PCs, you need to activate the second monitor or TV out in your Display properties.
In your NEC VT575, you need to select the source manually if the auto source detect does not work.
In some cases, the PC's output whether S-Video or Composite would be detected by a projector but would still fail to display on the projector's screen. The reason is the PC's Screen resolution is higher than what the projector can handle. You need to lower the said Screen resolution in the PC's Desktop Properties/Settings. The NEC VT575 can handle max 1024 X 768 but would suggest you try lower settings first in your PC and gradually work the resolution upwards till it blanks out.
In some instances, the projector simply fails to detect incoming video signals and the only solution is to wait till autodetected. At times it is really a projector's fault. it may be necessary to send the unit in for service/upgrade of firmware or hardware fault diagnosis/repairs.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information. It would be of help if you can likewise post brand/models of the PCs that would be used.
Good luck and kind regards.
Posted on Feb 02, 2008
  • 63 Answers
You mustn't have them plugged in. So try pulling them out then plugging them in. If this doesn't work you will probably need new cords. When buying the cords keep receipt in case you need to get a refund because it was'nt the problem. Also make sure they are plugged inthe right spot!
Hope this helps - Josh
NOTE : PLEASE GIVE FEEDBACK If you don't in seven days it will be presumed i fixed the problems.
How can I get the best video image quality with Nec np1000 projector ?
Your best option is using the COMPONENT IN input of the projector (Y, Cb, Cr). Though the highest video signal the projector will support is 1080i.
May 09, 2014 | NEC Televison & Video
No red in picture but red lines on screen
Not familiar with this projector, is it 3 CCD? if not, it might be using a color wheel and from the sound of it the red is broken off...
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 21, 2013 | NEC VT575 Multimedia Projector
Message
Reduce the screen resolution to 600x480 for instance and see if the projector can handle the low res output OK. Then increase screen resolution on the PC unitl the error message appears. Try the video menu settings in the acer
Jul 17, 2010 | Acer X1230 DLP Projector
The nec vt575 shows an image on the projector but not from laptop
this is very simple, its just a matter of a bios upgrade for your laptop
Mar 23, 2010 | NEC VT575 Multimedia Projector
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Vt575 pROJECTOR
My VT440 says this when it gets to it's pre-defined service life. (a certain amount of hours)
As long as you pop the filters out regularly and clean them (I use a vacuum cleaner) you shouldn't need to replace them.
After that, go into the projector options (with the remote control) and reset the factory defaults... otherwise it has no idea that you have actually changed the darn thing and keeps complaining no matter what! =-]
Aug 20, 2008 | NEC VT460 Multimedia Projector
Questions about Onkyo SR505
1, remote codes, check with sayno for code updates. Or consider a harmony remove last remote you will every buy.
2. Receiver does not convert video standards, need svideo cable.
3. popcorn hour player, no idea what that is , but like number 2. will need a seperate hdmi cable.
However, if the receiver and the player both have component, i would not hesitate to wore everything up component. In your application component video is better than hdmi. To many reasons to list. Good luck
Jun 10, 2008 | Onkyo TX-SR505 Receiver
No Image nec vt465 and yamaha rx v540
You must use the projectors menu to choose the type of input for video out. Your projector is capable of 720p or 1080i high def, but not through s video. If you want high def you must use the component output from your receiver to input on your projector. I hope this helps.
Jan 23, 2008 | Audio Players & Recorders
NEC VT575 Multimedia Projector Logo
148 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
