Question about SanDisk Sansa e250 MP3 Player
Screen color messed up, won't connect correct
Ok i have a couple of problems with my sansa e250, ive only had it for a couple months then i started to mess up:
THE FIRST PROBLEM:THE SCREENS COLORS ARE MESSED UP
i don't know what is wrong with it one day i just turned it on and the colors were all screwed up. all the images on the screen appear to be multicolored outlined and blurry. i tried restarting it and it didn't work
THE SECOND PROBLEM: WONT CONNECT
every time i plug the usb into the computer it recognizes it as a new drive and on the mp3 it boots up and says connected, then a couple of seconds later it says disconnects and then disconnects from the computer. it goes back to the sandisk screen and then the process repeats about 10 times and then just goes back to the sandisk screen and stays there although plugged into the computer and isn't recognized.
usually when it messes up and freezes i would just go and run a disk check and error fix on my computer and it fixes itself but it wouldnt help these problems.
SOMEONE PLEEEEAASE HELP!!!!
  • Anonymous Feb 02, 2008
    Every time i plug my sansa into the computer and it says its connected, but then a little while later it says it is disconnected. Help Please.
  • bballplyer11 Feb 07, 2008
    when i plug my sansa into the computer the screen says that it is connecting and i can see that it is charging, but it never says connected and the computer doesnt recognize it. any suggestions?
  • 69 Answers
Well can you come into recovery mode? hold(activated) push rec button and hold it while start your mp4 if it works get me information about it..
Posted on Feb 07, 2008
My SanDisk Sansa e250 MP3 Player is messed up.
sounds like a defective battery i would consider purchasing a new one, i have the same player ive never had that problem but these players are a bit dickey with computer connections
Apr 06, 2009 | SanDisk Sansa e250 MP3 Player
Hi, how do I format my sansa?
you connect it to the computer then go to my computer
then find the sansa and right click then press format
Dec 07, 2008 | SanDisk Sansa e250 MP3 Player
Wont load
hi try this
1 with mp3 player off switch lock/hold button to on
2 press and hold rec button on left hand side keep held down
3 switch on whilst still holding down rec
4 it should now say recovery mode
dont do nothing now dont connect to computer before you do this goto sandisk website and download the latest firmware once downloaded open the file then it will take you through the process of updating the firmware ok
let me know how you get on ok and if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
What would recovery mode do for my problem
what resolution are your images? without knowing if your pictures are set to 256 colors thats too low, 32 bit colors are too high. i think that 16 bit is what works.
hope this helps
Feb 10, 2008 | SanDisk Sansa e250 MP3 Player
My SanDisk sansa e250 wont sync
try reseting it to factory settings. in other words put it into recovery mode. to do this simply plug it into your computer, then push the hold button down so the orange is showing. then push and hold the record button on the side of it and push and hold the power button. if you do this correctly it should work. heres a link to the sansa forums just in case http://forums.sandisk.com/sansa/board?board.id=e200
best of luck friend! : ) dont give up!
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Connection/ Transferring tracks problems with Rhapsody.
left it charging over night and all the music erased...
Nov 26, 2007 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database screen
Hi tt, First, I would delete all the files in your Sansa>Music folder - you may have a corrupt or un-recognizable file that is stalling your "refresh". Check and see if your player refreshes correctly - if it does, update the firmware (see below). If this doesn't stop the problem, you may have to format your player - Windows Explorer>right click on Sansa Player>Format>make sure it is FAT32 and unclick "quick format">Start. You will lose all files that you have not backed up - but your player should start up correctly. Then, make sure that you have the latest firmware update - here is the place to get the updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 - instructions are on the site. After the update, add the files again and see if the unit refreshes - if it does not - it's probably a bad file. The only thing you can do is to add the files singly (or in small batches) until you find the problem file - I hope that you do not need to go this far! Sandisk has fixed most of the software problems that folks encountered in the last six months - IF you keep you keep up with the firmware upgrades. BTW - I have had my Sansa e250 for two months and have had zero problems - I LOVE it! Hope this helps, Steve
Jan 03, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa E250 Froze..
that happened to me once. all i had to do is hold down the power button for at least 15 seconds sometimes more. if not call tech support
Jan 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
88 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
