Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Red Shadow One minute our Sony KP - 51WS510, the next minute, when turned off and then back on, a red shadow appeared on every channel. Other TV's in the home are fine, it seems to be an issue with this TV. I'm not a technician, so please respond in laymen's terms. What seems to be the problem?
  • Todd Braschler
    Todd Braschler Feb 02, 2008
    What's your suggestion on replacing this confergence circuit? Is this something an owner can do, or does a professional need to tackle the job?
  • 21 Answers
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Posted on Feb 02, 2008
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
I replaed the convergance chips and still have a red shadow on my sony 51 inch projection tv
This set has two 5 amp fuses on power board that feed the convergence circuit, did you test them?
I needed I can provide photo of that board, fuses are pico fuses and not glass.
Let me know and I will be happy to help you.
SD TECH
Nov 06, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The STK392-560 ICs have gone bad. They need to be replaced by a qualified TV2_bing.gif technician. The repair cost is from $200 and up.
Best of Luck
Nour BMI
Feb 17, 2010 | Sony Televison & Video
Shadow
The sony convergence Kit Type 1 available at the following link will usually repair that issue. The kit contains the parts plus a CD with detailed instructions to do the repair.
www.tvrepairkits.net
Jun 25, 2009 | Sony KP-46WT500 46" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS510
Your tv has a convergence board problem. Two convergence IC's need to be replaced.
Jul 22, 2008 | Sony KP-51WS510 51" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
