On some systems F61 is to do with the fan not working properly, sometimes blocked with dust. On others it's a power amplifier failure. Yours does sound like a power amp problem, but both should be checked.
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
If you check at the back of your hi-fi, you'll see a projection at the top where the cooler fan is located. The most likely reason is that your fan is not working (as required). In this system, the fan is turned on automatically at high volumes >=10, because then, the amplifier starts to get a temperature rise and without proper cooling the system might fault.
Try check and see if at these high volumes the fan is running, if not, then that's what needs to be fixed. Alternatively you can try running an external fan to see if it will produce the desired cooling effect.
An equaliser is, put simply, a more complex tone control, giving you the ability to cut or boost more specific frequencies than a tone knob, or bass & treble controls.
It comes in handy for tweaking the sound from your hi-fi to just the way you like it. But beware, as it can make your hi-fi produce sounds that are so bass or treble heavy, that you can damage your speakers if you're not careful.
Adding another compnent into the chain (like a graphic EQ) can add a little background noise but this Technics EQ is a pretty quiet one & you probably won't notice the noise apart from when there's no music playing & you've got the amp turned up high.
