Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca model P60752EB does not turn on.
I read someone elses tv did not turn on. They said to check the power, I did that, power is fine. They also said to check the fuse, is there one in the tv that I should be checking and where is it.
  • vickingfan Feb 03, 2008
    Our 52" would automatically shut off shortly after turning it on. Waiting a minute or two helped. The last time it shut off, it appeared to be turning back on, but only a click/buzz sound wasemitted. We are unable to get it to power back on. Any suggestions? You know, unfortunately, it is Super Bowl Sunday!
  • chris konakowitz Feb 04, 2008
    It does nothing, I kind of hear something when I do plug it in but it is very faint.
  • 1,030 Answers
This particular rca also know as a itc222 chasis has a safety shutdown cuircit.. if it detect any problem. high voltage. over current over voltage of 20 problems. it will shut down. if the unit tries to come on that idicates its more than just a fuse. first question u ask is after the set been unplug for 30 minites then plug back up does the set come on or try to come on does the led light flash on the front. does it try to come on 3 times then shut down. there is special diagnostic equipment techs used to read errors recorded in the processor.
Posted on Feb 04, 2008
My RCA p60752eb does not come on its makes a crackling sound, but does nothing else
u may have a bad capacitor on power supply 2200uf 25v, just look at the power supply this cap is big u can not miss it
Aug 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have an RCA 60" rear projection tv (Model: P60752EB, Chassis: PTK169PEC). TV will not turn on. While pressing the power button it will make a clicking noise. Otherwise, there is no picture or sound. Have...
It is the 169 chassis-over 300 different models used it and are different-answer something for me--does it have a GREEN power light that comes on for a second and goes off?
I know this set well and to be honest hated working on them--Let me know about the power light and I will tell you what I know.
At one point in time this was a very good set--I do understand about paying a lot to get it fixed and having it bad again.
I am here to help people and I bet I know more about this set than almost anyone else here.
Dec 14, 2009 | RCA P60921 60" Rear Projection Television
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
RCA p60752eb no picture porblem
most likely its a vertical deflection issue, try soldering the vertical otput IC as that may just need to be resolderd, if that doesnt help try replacing the Vertical output.
Sep 16, 2008 | RCA P60828 TV
Rca p60752eb
Sounds like the flyback, can you look on the rear tag and let me know which chassis you have and verify your model number and I will post which flyback you need as well as where to get a replacement with free tech support to help you install it.
Jul 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P60752EB Power problem
Apparently, blown fuses indicate problems elsewhere in the circuit. The block is a voltage dropping resistor, has nothing to do with problem. If you think it's worth it, take to pro/tech
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p60752eb
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
Feb 11, 2008 | RCA P61960 61" Rear Projection Television
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
Rca projection tv has sound,no picture or OSD
The 169 is an old chasis but a good one. Many chronc problems can cause these symtons. No high voltage because of bad flyback, or HV spitter defec is the most likely, but there are chonic caps that fail in the power supply as well. This problem will most likely need the assistance of a qualified service professional.
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
